[mapserver-users] problem with Symbol and Style
Valeria Munoz I
valemunoz at gmail.com
Sun Aug 28 14:30:04 EDT 2011
Can i display a outliner?
Thanks for the reply!!
Enviado desde mi iPhone
El 27-08-2011, a las 17:44, Havard Tveite <havard.tveite at umb.no> escribió:
> Valeria,
> To display simple lines (in the latest versions of
> Mapserver), you should take away the SYMBOL from the
> STYLE, and specify the WIDTH of the line (not the
> SIZE). You can skip ANTIALIAS (you can't even turn
> it off for AGG).
> STYLE
> WIDTH 12
> COLOR 200 112 64
> END
> STYLE
> WIDTH 10
> COLOR 224 136 72
> END
> Håvard
> On 26/08/11 23:32, Valeria Muñoz wrote:
>> HI!!!
>> i have problem with my mapfile. i'm trying to display street but i just
>> get circle like this not a continuous and perfect line.
>> my mapserver version is 6.
>> please help!!
>> my code is:
>> LAYER
>> NAME 'RM'
>> TYPE LINE
>> MAXSCALE 15000
>> LABELMAXSCALE 15000
>> MINSCALE 5000
>> LABELMINSCALE 5000
>> DATA 'street.shp'
>> METADATA
>> 'wms_title'RM'
>> END
>> STATUS DEFAULT
>> TRANSPARENCY 100
>> PROJECTION
>> 'proj=longlat'
>> 'ellps=WGS84'
>> 'datum=WGS84'
>> 'no_defs'
>> END
>> LABELITEM 'NAME'
>> CLASS
>> NAME 'c_RM'
>> STYLE
>> SYMBOL 'linecc'
>> ANTIALIAS TRUE
>> SIZE 12
>> COLOR 200 112 64
>> END
>> STYLE
>> SYMBOL 'defline'
>> ANTIALIAS TRUE
>> SIZE 10
>> COLOR 224 136 72
>> END
>> LABEL
>> TYPE truetype
>> FONT 'arialbd'
>> SIZE 9
>> MINSIZE 9
>> MAXSIZE 9
>> ANTIALIAS TRUE
>> COLOR 25 25 25
>> ANGLE FOLLOW
>> FORCE FALSE
>> POSITION cc
>> BUFFER 10
>> MINDISTANCE 7000
>> MINFEATURESIZE 50
>> OFFSET 0 0
>> PARTIALS FALSE
>> END
>> END
>> END
>> Symbol
>> Name 'linecc'
>> Type ELLIPSE
>> Filled TRUE
>> ANTIALIAS TRUE
>> Points
>> 1 1
>> END
>> END
>> Symbol
>> Name 'defline'
>> Type ELLIPSE
>> Filled TRUE
>> ANTIALIAS TRUE
>> Points
>> 1 1
>> END
>> END
> mapserver-users at lists.osgeo.org
