[mapserver-users] msQueryByFilter(): Search returned no results.
    Steve Lime
    sdlime at gmail.com
    Sun Aug 28 21:30:43 PDT 2011
Looking at the code the correct projection work is done. I wonder if
there's something funky projecting the globe (-180 -90 180 90) to
epsg:102067.
Steve
2011/8/26 Steve Lime <sdlime at gmail.com>:
> Ok, definitely a bug here... Will take a look. Steve
> 2011/8/26 Michal Šrédl <michal.sredl at gmail.com>:
>> Hi Steve,
>> for epsg:4326 and url
>> http://localhost//cgi-bin/ows?mode=itemnquery&qlayer=typ&qitem=zver&qstring=2
>> it says
>> msQueryByAttributes(): Search returned no results. No matching
>> record(s) found, layer and area of interest do not overlap.
>> Cheers,
>> Mike
>>> You must have a default mapfile set in apache, that's cool. Use the second URL.
>>> Change qstring_validation to qstring_validation_pattern from my first
>>> message, my mistake.
>>> Steve
>>>> Hi Steve,
>>>> regardless of the projection settings, I get the following result:
>>>> For
>>>>  http://localhost//cgi-bin/ows?map=mapfile&mode=itemnquery&qlayer=typ&qitem=zver&qstring=2
>>>> I see
>>>>  msLoadMap(): Regular expression error. MS_DEFAULT_MAPFILE_PATTERN
>>>> validation failed. msEvalRegex(): Regular expression error. String
>>>> failed expression test.
>>>> And for
>>>> I see
>>>>  mapserv(): Web application error. Parameter 'qstring' value fails to
>>>> validate. msValidateParameter(): Regular expression error. Parameter
>>>> pattern validation failed.
>>>> Cheers,
>>>> Michal
>>>>> I would agree this sounds like a bug. The map extent *should* be
>>>>> projected to the layer extent and that's what's used to identify
>>>>> candidate features. Can you check what happens with a native mapserver
>>>>> attribute query in this case? If possible try this:
>>>>> 1) set your MAP projection back to geographic, and restore your
>>>>> geographic map extent.
>>>>> 2) add this line to the layer metadata 'qstring_validation' '^[0-9]$'
>>>>> 3) go to the following URL:
>>>>>  http://localhost//cgi-bin/ows?map=[yourmapfile]&mode=itemnquery&qlayer=typ&qitem=zver&qstring=2
>>>>> and see what happens.
>>>>> This will run a different query function msQueryByAttributes() that's
>>>>> not new to 6.0.x.
>>>>> Steve
>>>>>> Hi Jukka,
>>>>>> the current settings returns expected result with &srsName=EPSG:4326
>>>>>> as well. The original settings doesn't work neither with
>>>>>> &srsName=EPSG:4326 nor &srsName=EPSG::102067.
>>>>>> Yes, it looks like there would be a problem in case of several WFS
>>>>>> layers with different projections of the source data.
>>>>>> Cheers,
>>>>>> Mike
>>>>>> 2011/8/26 Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi>:
>>>>>>> Hi,
>>>>>>> Good that you could make it to work. However, this feels maybe like a bug if it means that using ogc:PropertyIsEqualTo filter without any other filter works only if projection of the source data is the same than the default output projection from WFS.
>>>>>>> Could you have one more trial with the original settings and see if adding &srsName=EPSG:4326 or &srsName=EPSG::102067 is changing anything? And also if your current setting gives correct result with &srsName=EPSG:4326.
>>>>>>> -Jukka Rahkonen.
>>>>>>> Michal Šrédl wrote:
>>>>>>>> Hi all,
>>>>>>>> problem solved. I needed to set:
>>>>>>>> EXTENT -905000 -1230000 -400000 -900000
>>>>>>> and
>>>>>>> PROJECTION
>>>>>>> ##  "init=epsg:4326"
>>>>>>>  "init=epsg:102067"
>>>>>>> END
>>>>>>> (Epsg 102067 is the projection of the layer being filtered.)
>>>>>>> Thank you very much again,
>>>>>>> Michal
>>>>>>> 2011/8/25 Michal Šrédl <michal.sredl at gmail.com>:
>>>>>>>> Hi Steve,
>>>>>>>> Thanks a lot. The extent should be large enough to encompass all the
>>>>>>>> features. Here comes the whole mapfile:
>>>>>>>> MAP
>>>>>>>> NAME "MIS WFS Server"
>>>>>>>> STATUS ON
>>>>>>>> SIZE 500 500
>>>>>>>> EXTENT -180 -90 180 90
>>>>>>>> SHAPEPATH "data/"
>>>>>>>> IMAGECOLOR 255 255 255
>>>>>>>> CONFIG MS_ERRORFILE "log/mapserv.log"
>>>>>>>> DEBUG 5
>>>>>>>> WEB
>>>>>>>>  IMAGEPATH "/var/www/tmp/"
>>>>>>>>  IMAGEURL "/tmp/"
>>>>>>>>  METADATA
>>>>>>>>    "wfs_title"            "MIS WFS Server"  ## REQUIRED
>>>>>>>>    "wfs_onlineresource"   "http://127.0.0.1/cgi-bin/ows?"
>>>>>>>>    "wfs_srs"               "EPSG:4326 EPSG:102067"
>>>>>>>>    "wms_srs"               "EPSG:4326 EPSG:102067"  ## Recommended
>>>>>>>>    "wcs_srs"               "EPSG:4326 EPSG:102067"  ## Recommended
>>>>>>>>    "ows_enable_request" "*"
>>>>>>>>    "ows_updatesequence" "2011-29-05T00:24:00"
>>>>>>>>  END
>>>>>>>> END
>>>>>>>> PROJECTION
>>>>>>>>  "init=epsg:4326"
>>>>>>>> END
>>>>>>>> LAYER
>>>>>>>>  NAME "typ"
>>>>>>>>  METADATA
>>>>>>>>    "wfs_title"    "Typologie" ## REQUIRED
>>>>>>>>    "wfs_include_items" "all"
>>>>>>>>    "gml_featureid" "CISLO" ## REQUIRED
>>>>>>>>    "gml_include_items" "all"  ## Optional (serves all attributes for layer)
>>>>>>>>    "gml_types" "auto"
>>>>>>>>    "gml_geometries" "msGeometry"
>>>>>>>>    "gml_msGeometry_type" "polygon"
>>>>>>>>  END
>>>>>>>>  DATA typ.shp
>>>>>>>>  TYPE POLYGON
>>>>>>>>  STATUS ON
>>>>>>>>  PROJECTION
>>>>>>>>    "init=epsg:102067"
>>>>>>>>  END
>>>>>>>>  DUMP TRUE           ## REQUIRED
>>>>>>>>  CLASS
>>>>>>>>    NAME "Typ"
>>>>>>>>    STYLE
>>>>>>>>      COLOR 0 0 155
>>>>>>>>      OUTLINECOLOR 120 120 120
>>>>>>>>    END
>>>>>>>>    TEMPLATE "templates/typ_zver.html"
>>>>>>>>  END
>>>>>>>>  DEBUG 5
>>>>>>>> END # Layer
>>>>>>>> LAYER
>>>>>>>>    NAME "hsrs"
>>>>>>>>    TYPE RASTER
>>>>>>>>    STATUS ON
>>>>>>>>    CONNECTION "http://www.bnhelp.cz/cgi-bin/crtopo?"
>>>>>>>>    DEBUG ON
>>>>>>>>    CONNECTIONTYPE WMS
>>>>>>>>    METADATA
>>>>>>>>        "wms_srs"             "EPSG:4326"
>>>>>>>>        "wms_name"            "obce,kraje,hr_cr,sidla,doprava"
>>>>>>>>        "wms_title"            "CR Topo"
>>>>>>>>        "wms_server_version"  "1.1.1"
>>>>>>>>        "wms_format"          "image/png"
>>>>>>>>        "wms_latlonboundingbox" "11.9384 48.2337 18.957 51.3549"
>>>>>>>>    END
>>>>>>>> END
>>>>>>>> END # Map File
>>>>>>>> Cheers,
>>>>>>>> Michal
>>>>>>>> 2011/8/25 Steve Lime <sdlime at gmail.com>:
>>>>>>>>> What is your default EXTENT set to in your mapfile? It should be large enough to encompass all features. - Steve
>>>>>>>>> Sent from my iPad
>>>>>>>>> On Aug 24, 2011, at 7:58 AM, Michal Šrédl <michal.sredl at gmail.com> wrote:
>>>>>>>>>> Hi all,
>>>>>>>>>> I am trying to use FES filter for WFS layer and get no result, even
>>>>>>>>>> thought I should get one.
>>>>>>>>>> In my browser, I request
>>>>>>>>>> http://localhost//cgi-bin/ows?&REQUEST=GetFeature&VERSION=1.1.0&SERVICE=WFS&TYPENAME=typ&FILTER=<ogc:Filter
>>>>>>>>>> xmlns:ogc="http://www.opengis.net/ogc"><ogc:PropertyIsEqualTo><ogc:PropertyName>ZVER</ogc:PropertyName><ogc:Literal>2</ogc:Literal></ogc:PropertyIsEqualTo></ogc:Filter>
>>>>>>>>>> and get
>>>>>>>>>> <wfs:FeatureCollection
>>>>>>>>>> xmlns:ms="http://mapserver.gis.umn.edu/mapserver"
>>>>>>>>>> xmlns:gml="http://www.opengis.net/gml"
>>>>>>>>>> xmlns:wfs="http://www.opengis.net/wfs"
>>>>>>>>>> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>>>>>>>>>> xsi:schemaLocation="http://mapserver.gis.umn.edu/mapserver
>>>>>>>>>> http://127.0.0.1/cgi-bin/ows?SERVICE=WFS&VERSION=1.1.0&REQUEST=DescribeFeatureType&TYPENAME=typ&OUTPUTFORMAT=text/xml;%20subtype=gml/3.1.1
>>>>>>>>>> http://schemas.opengis.net/wfs/1.1.0/wfs.xsd">
>>>>>>>>>> <gml:boundedBy>
>>>>>>>>>> <gml:Null>missing</gml:Null>
>>>>>>>>>> </gml:boundedBy>
>>>>>>>>>> </wfs:FeatureCollection>
>>>>>>>>>> even though I do know, that features with ZVER=2 do exist.
>>>>>>>>>> In the mapserver log file, I get
>>>>>>>>>> [Wed Aug 24 14:48:52 2011].296607 msQueryByFilter(): Search returned
>>>>>>>>>> no results. No matching record(s) found.
>>>>>>>>>> [Wed Aug 24 14:48:52 2011].296747 mapserv request processing time
>>>>>>>>>> (msLoadMap not incl.): 0.002s
>>>>>>>>>> [Wed Aug 24 14:48:52 2011].296764 msFreeMap(): freeing map at 0x2783120.
>>>>>>>>>> [Wed Aug 24 14:48:52 2011].296773 freeLayer(): freeing layer at 0x278b570.
>>>>>>>>>> I have checked http://mapserver.org/errors.html#id2 with similar error
>>>>>>>>>> "msQueryByPoint: search returned no results" and tried to create a
>>>>>>>>>> simple template:
>>>>>>>>>> <!-- MapServer Template -->
>>>>>>>>>> <tr>
>>>>>>>>>>  <td>[lrn]</td>
>>>>>>>>>>  <td>[ZVER]</td>
>>>>>>>>>> </tr>
>>>>>>>>>> but with no effect.
>>>>>>>>>> In the mapfile, there is
>>>>>>>>>> LAYER
>>>>>>>>>>  NAME "typ"
>>>>>>>>>>  METADATA
>>>>>>>>>>    "gml_types" "auto"
>>>>>>>>>>  END
>>>>>>>>>>  DATA typ.shp
>>>>>>>>>>  TYPE POLYGON
>>>>>>>>>>  STATUS ON
>>>>>>>>>>  PROJECTION
>>>>>>>>>>    "init=epsg:102067"
>>>>>>>>>>  END
>>>>>>>>>>  CLASS
>>>>>>>>>>    NAME "Typ"
>>>>>>>>>>    STYLE
>>>>>>>>>>      COLOR 0 0 155
>>>>>>>>>>    END
>>>>>>>>>>  END
>>>>>>>>>>  DEBUG 5
>>>>>>>>>> END # Layer
>>>>>>>>>> What is wrong with my FES filter? How can I make it to run?
>>>>>>>>>> Thanks a lot,
>>>>>>>>>> Michal
>>>>>>>>>> _______________________________________________
>>>>>>>>>> mapserver-users mailing list
>>>>>>>>>> mapserver-users at lists.osgeo.org
>>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
More information about the MapServer-users
