[mapserver-users] problem with Symbol and Style
Havard Tveite
havard.tveite at umb.no
Mon Aug 29 08:29:15 EDT 2011
The example I provided should give you an outline
(color 200 112 64).
Håvard
On 8/28/2011 8:30 PM, Valeria Munoz I wrote:
> Can i display a outliner?
> Thanks for the reply!!
> Enviado desde mi iPhone
> El 27-08-2011, a las 17:44, Havard Tveite<havard.tveite at umb.no> escribió:
>> Valeria,
>> To display simple lines (in the latest versions of
>> Mapserver), you should take away the SYMBOL from the
>> STYLE, and specify the WIDTH of the line (not the
>> SIZE). You can skip ANTIALIAS (you can't even turn
>> it off for AGG).
>> STYLE
>> WIDTH 12
>> COLOR 200 112 64
>> END
>> STYLE
>> WIDTH 10
>> COLOR 224 136 72
>> END
>> Håvard
>> On 26/08/11 23:32, Valeria Muñoz wrote:
>>> HI!!!
>>> i have problem with my mapfile. i'm trying to display street but i just
>>> get circle like this not a continuous and perfect line.
>>> my mapserver version is 6.
>>> please help!!
>>> my code is:
>>> LAYER
>>> NAME 'RM'
>>> TYPE LINE
>>> MAXSCALE 15000
>>> LABELMAXSCALE 15000
>>> MINSCALE 5000
>>> LABELMINSCALE 5000
>>> DATA 'street.shp'
>>> METADATA
>>> 'wms_title'RM'
>>> END
>>> STATUS DEFAULT
>>> TRANSPARENCY 100
>>> PROJECTION
>>> 'proj=longlat'
>>> 'ellps=WGS84'
>>> 'datum=WGS84'
>>> 'no_defs'
>>> END
>>> LABELITEM 'NAME'
>>> CLASS
>>> NAME 'c_RM'
>>> STYLE
>>> SYMBOL 'linecc'
>>> ANTIALIAS TRUE
>>> SIZE 12
>>> COLOR 200 112 64
>>> END
>>> STYLE
>>> SYMBOL 'defline'
>>> ANTIALIAS TRUE
>>> SIZE 10
>>> COLOR 224 136 72
>>> END
>>> LABEL
>>> TYPE truetype
>>> FONT 'arialbd'
>>> SIZE 9
>>> MINSIZE 9
>>> MAXSIZE 9
>>> ANTIALIAS TRUE
>>> COLOR 25 25 25
>>> ANGLE FOLLOW
>>> FORCE FALSE
>>> POSITION cc
>>> BUFFER 10
>>> MINDISTANCE 7000
>>> MINFEATURESIZE 50
>>> OFFSET 0 0
>>> PARTIALS FALSE
>>> END
>>> END
>>> END
>>> Symbol
>>> Name 'linecc'
>>> Type ELLIPSE
>>> Filled TRUE
>>> ANTIALIAS TRUE
>>> Points
>>> 1 1
>>> END
>>> END
>>> Symbol
>>> Name 'defline'
>>> Type ELLIPSE
>>> Filled TRUE
>>> ANTIALIAS TRUE
>>> Points
>>> 1 1
>>> END
>>> END
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
Håvard Tveite
Department of Mathematical Sciences and Technology, UMB
Drøbakveien 31, POBox 5003, N-1432 Ås, NORWAY
Phone: +47 64965483 Fax: +47 64965401 http://www.umb.no/imt/
