[mapserver-users] problem with Symbol and Style
Valeria Munoz I
valemunoz at gmail.com
Mon Aug 29 09:55:08 EDT 2011
Thanks a lot!
Enviado desde mi iPhone
El 29-08-2011, a las 8:29, Havard Tveite <havard.tveite at umb.no> escribió:
> The example I provided should give you an outline
> (color 200 112 64).
> Håvard
> On 8/28/2011 8:30 PM, Valeria Munoz I wrote:
>> Can i display a outliner?
>> Thanks for the reply!!
>> El 27-08-2011, a las 17:44, Havard Tveite<havard.tveite at umb.no> escribió:
>>> Valeria,
>>> To display simple lines (in the latest versions of
>>> Mapserver), you should take away the SYMBOL from the
>>> STYLE, and specify the WIDTH of the line (not the
>>> SIZE). You can skip ANTIALIAS (you can't even turn
>>> it off for AGG).
>>> STYLE
>>> WIDTH 12
>>> COLOR 200 112 64
>>> END
>>> STYLE
>>> WIDTH 10
>>> COLOR 224 136 72
>>> END
>>> Håvard
>>> On 26/08/11 23:32, Valeria Muñoz wrote:
>>>> HI!!!
>>>> i have problem with my mapfile. i'm trying to display street but i just
>>>> get circle like this not a continuous and perfect line.
>>>> my mapserver version is 6.
>>>> please help!!
>>>> my code is:
>>>> LAYER
>>>> NAME 'RM'
>>>> TYPE LINE
>>>> MAXSCALE 15000
>>>> LABELMAXSCALE 15000
>>>> MINSCALE 5000
>>>> LABELMINSCALE 5000
>>>> DATA 'street.shp'
>>>> METADATA
>>>> 'wms_title'RM'
>>>> END
>>>> STATUS DEFAULT
>>>> TRANSPARENCY 100
>>>> PROJECTION
>>>> 'proj=longlat'
>>>> 'ellps=WGS84'
>>>> 'datum=WGS84'
>>>> 'no_defs'
>>>> END
>>>> LABELITEM 'NAME'
>>>> CLASS
>>>> NAME 'c_RM'
>>>> STYLE
>>>> SYMBOL 'linecc'
>>>> ANTIALIAS TRUE
>>>> SIZE 12
>>>> COLOR 200 112 64
>>>> END
>>>> STYLE
>>>> SYMBOL 'defline'
>>>> ANTIALIAS TRUE
>>>> SIZE 10
>>>> COLOR 224 136 72
>>>> END
>>>> LABEL
>>>> TYPE truetype
>>>> FONT 'arialbd'
>>>> SIZE 9
>>>> MINSIZE 9
>>>> MAXSIZE 9
>>>> ANTIALIAS TRUE
>>>> COLOR 25 25 25
>>>> ANGLE FOLLOW
>>>> FORCE FALSE
>>>> POSITION cc
>>>> BUFFER 10
>>>> MINDISTANCE 7000
>>>> MINFEATURESIZE 50
>>>> OFFSET 0 0
>>>> PARTIALS FALSE
>>>> END
>>>> END
>>>> END
>>>> Symbol
>>>> Name 'linecc'
>>>> Type ELLIPSE
>>>> Filled TRUE
>>>> ANTIALIAS TRUE
>>>> Points
>>>> 1 1
>>>> END
>>>> END
>>>> Symbol
>>>> Name 'defline'
>>>> Type ELLIPSE
>>>> Filled TRUE
>>>> ANTIALIAS TRUE
>>>> Points
>>>> 1 1
>>>> END
>>>> END
>>> mapserver-users mailing list
>>> mapserver-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> Håvard Tveite
> Department of Mathematical Sciences and Technology, UMB
> Drøbakveien 31, POBox 5003, N-1432 Ås, NORWAY
> Phone: +47 64965483 Fax: +47 64965401 http://www.umb.no/imt/
