[mapserver-users] wrong tileindex path make mapserver 6 crash
Jeff McKenna
jmckenna at gatewaygeomatics.com
Tue Aug 30 09:17:59 EDT 2011
Hello,
When I need info like that during testing of tileindexes, I always use
the shp2img commandline utility
(http://www.mapserver.org/utilities/shp2img.html) with the "-all_debug"
switch (see examples on that page).
Hope that helps.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 11-08-30 7:40 AM, Oliver Christen wrote:
> hello
> Im just wondering if it was normal for mapserver 6 to crash instead of
> returning an error message if a tileindex path was incorrect for a
> raster layer ?
> Im using 6.0.0-1
> I have a raster layer using a tileindex (ortho/ortho.*):
> LAYER
> NAME 'ortho'
> TYPE RASTER
> STATUS ON
> TILEINDEX "ortho/ortho"
> TILEITEM "LOCATION"
> END
> at first the TILEINDEX was wrong set to "ortho", so effectively pointing
> to the folder instead of the files, which is of course wrong, but I
> would have expected an error message, not a crash.
> all I have in my error log is:
> mod_fcgid: error reading data, FastCGI server closed connection
> Premature end of script headers: mapserv
> I tried to turn on the debug with:
> CONFIG "MS_ERRORFILE" "/tmp/ms_error.txt"
> DEBUG 5
> CONFIG "CPL_DEBUG" "ON"
> but ms_error.txt is empty
> is there any way to be able to obtain some error message which may help
> knowing where the error is?
> would this problem be fixed in 6.0.1?
> thanks in advance
> best regards
> Oliver
