[mapserver-users] Re: Invalid SRS given: SRS must be valid for
all requested layers. EPSG 23030
Mr. Puneet Kishor
punk.kish at gmail.com
Tue Aug 30 12:58:41 EDT 2011
On Aug 30, 2011, at 11:21 AM, Amalia Carolina Canavire wrote:
> hi ,I don't good speak english, but i don't understand you, when you say
> "Projection must be in meters which seem to be the unit for the EPSG:23030
> units", you can specify in where may correction in this code, please. thank
> for you time and helping.
Your declared projection "EPSG:23030" uses meters, but your extent `EXTENT -82.65814999999999 29.435378999999998 -82.05008 29.943614` is definitely not in meters (unless, you are plotting a very tiny and strange area of the world that is only a few centimeters wide and long). Make sure your extent and projection units match.
> 2011/8/30 Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi>
>> Hi,
>> I do not understand Spanish but it looks like you have something wrong with
>> projections.
>> MAP
>> PROJECTION
>> "init=epsg:23030"
>> END
>> units
>> http://www.epsg-registry.org/report.htm?type=selection&entity=urn:ogc:def:crs:EPSG::23030&reportDetail=short&style=urn:uuid:report-style:default-with-code&style_name=OGP%20Default%20With%20Code&title=
>> The same with "wms_extent" "-82.65814999999999 29.435378999999998 -82.05008
>> 29.943614"
>> use extents in the EPSG:23030 system and units.
>> -Jukka Rahkonen-
>> ________________________________
>> Lähettäjä: mapserver-users-bounces at lists.osgeo.org [
>> mapserver-users-bounces at lists.osgeo.org] käyttäjän Amalia Carolina
>> Canavire [acarolinagc at gmail.com] puolesta
>> Lähetetty: 30. elokuuta 2011 16:55
>> Vastaanottaja: Lista de Usuarios de gvSIG; mapserver-users at lists.osgeo.org
>> Aihe: [mapserver-users] msWMSLoadGetMapParams(): WMS server error. Invalid
>> SRS given: SRS must be valid for all requested layers. EPSG 23030
>> Hola gente, una duda usando gvsig para poder generar una vista desde un
>> .shp debo seleccionar una proyección epsg 23030, porque no me reconece epsg
>> 4326 (con esta opción mi vista es vacia , a que se debe?
>> Estoy usando gvsig 1.1 por la extensión de publicación, sobre ubuntu.
>> Debido a ello , por las dudas, respeto esta proyección epsg 23030, cuando
>> utilizo vista desde wms, me muestra sin problema, ahora cuando lo hago para
>> web, me sale el error de :
>> msWMSLoadGetMapParams(): WMS server error. Invalid SRS given: SRS must be
>> valid for all requested layers .
>> Si cambio la proyeccion a 4326, no sale el error pero no me muestra nada.
>> Mi codigo es el sgte:
>> MAP
>> NAME map_generated_by_gvsig
>> SIZE 600 400
>> SYMBOLSET "dmwms1.sym"
>> FONTSET "fonts.txt"
>> LEGEND
>> IMAGECOLOR -1 -1 -1
>> LABEL
>> FONT "vera"
>> ANGLE FOLLOW
>> COLOR 0 0 0
>> ENCODING "UTF-8"
>> TYPE truetype
>> SIZE 8
>> END
>> STATUS ON
>> TRANSPARENT ON
>> END
>> WEB
>> METADATA
>> "wms_encoding" "UTF-8"
>> "wms_title" "Mapserver WMS"
>> "wms_abstract" ""
>> "wms_srs" " EPSG:23030"
>> "wms_onlineresource" "
>> http://localhost/cgi-bin/mapserv?map=%2Fvar%2Fwww%2FgisParcelsFL%2Fmap%2Fdmwms1.map
>> END
>> END
>> PROJECTION
>> "init=epsg:23030"
>> END
>> LAYER
>> NAME "tl_2010_12001_roads.shp"
>> STATUS ON
>> TYPE LINE
>> DATA
>> "/var/www/gisParcelsFL/tl_2010_12001_roads/tl_2010_12001_roads.shp"
>> MAXSCALE -1.0
>> MINSCALE -1.0
>> TRANSPARENCY 100
>> SIZEUNITS pixels
>> LABELITEM "FULLNAME"
>> PROJECTION
>> "init=epsg:23030"
>> END
>> CLASS
>> STYLE
>> COLOR 153 153 153
>> WIDTH 1
>> END
>> NAME "default"
>> LABEL
>> FONT "vera"
>> ANGLE FOLLOW
>> COLOR 0 0 0
>> TYPE truetype
>> SIZE 7.0
>> END
>> END
>> METADATA
>> "wms_title" "tl_2010_12001_roads.shp"
>> "wms_abstract" "generated by gvSIG"
>> 29.943614"
>> "gml_include_items" "all"
>> END
>> END # Layer
>> END # Map File
>> ************** :) sonrei que te queda lindo :):):):): amy cgc
> *************** * :) *sonrei que te queda lindo :):):):): **amy **cgc
