[mapserver-users] Issue with run-time substitution?
pcreso at pcreso.com
Tue Aug 30 14:09:55 EDT 2011
One question...
>From a performance perspective, I would have thought that having the fliter
FILTER (stype='B' and uc='%vucv%')
inside the DATA statement SQL would be faster, as only the relevant records would be returned to mapserver, & Postgres would be more efficient at doing this.
Is there any advantage in using FILTER instead of an SQL WHERE clause for this?
Brent Wood
--- On Tue, 8/30/11, Julien Cigar <jcigar at ulb.ac.be> wrote:
Subject: Re: [mapserver-users] Issue with run-time substitution?
To: mapserver-users at lists.osgeo.org
Date: Tuesday, August 30, 2011, 11:49 PM
On 08/30/2011 13:43, Stephen Davies wrote:
> I am running mapserver 6.0.1 with map files migrated from 5.6.3.
> One of my map files has stopped working properly and I suspect that it may be a
> bug in the 6.0.1 run-time substitution code.
> The relevant map file layer sections look like this:
> LAYER
> CONNECTIONTYPE postgis
> NAME "battery"
> DATA "geom from wmd using unique id using SRID=4283"
> CONNECTION "user=scldad dbname=benparts"
> STATUS ON
> TYPE POINT
> VALIDATION
> vucv '[0-9]*_[0-9]*'
> END
> PROJECTION
> "init=epsg:4283"
> END
> MAXSCALE 5000000
> LABELITEM "label"
> CLASSITEM "state"
> CLASS
> EXPRESSION "G"
> STYLE
> COLOR 0 255 0
> SYMBOL 'dot'
> SIZE 7
> OFFSET 17 0
> END
> LABEL
> POSITION CR
> TYPE TRUETYPE
> FONT arial
> SIZE 8
> COLOR 0 255 0
> OFFSET 20 0
> FORCE TRUE
> STYLE
> GEOMTRANSFORM 'labelpoly'
> COLOR 255 255 255
> END
> END
> END
> END
> There are twelve layers with essentially the same definition apart from the
> STYPE values.
> The invoking URL has&vucv=137_11 but the postgresql log reveals that no
> substitution has occurred. The final pgsql command still has '%vucv%'.
> I suspect that having more than one FILTER with the same substitution breaks
> things as all other substitutions work fine.
> (I also tried putting the substitution in the DATA entry but with no better
> result.)
You should use a METADATA section, something like:
METADATA
"vucv_validation_pattern" '[0-9]*_[0-9]*'
END
instead of VALIDATION
> Cheers,
> Stephen
No trees were killed in the creation of this message.
However, many electrons were terribly inconvenienced.
-----Inline Attachment Follows-----
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110830/3536e6c5/attachment.html
