[mapserver-users] Bug or User error? MINSIZE not working
thomas bonfort
thomas.bonfort at gmail.com
Fri Feb 4 02:14:53 EST 2011
what are you trying to obtain?
* minsize/maxsize and minwidth/maxwidth are only used when doing
scale-dependent scaling of symbols (either by using sizeunits
different than pixels, or by having the symbolscaledenom activated)
* symbol STYLE is deprecated, and dots and caps are now set at the style level:
style
width 1
pattern 1 3 end
color "#aaaaaa"
end
thomas
On Fri, Feb 4, 2011 at 07:11, Stephen Woodbridge
<woodbri at swoodbridge.com> wrote:
> On 2/4/2011 12:19 AM, Rahkonen Jukka wrote:
>> Hi,
>> Documentation shows that MINSIZE under CLASS definitions, not STYLE.
>> Have you tried to place it there?
> Thanks, I did notice that after I posted. Sadly it does not work there
> either. It seems to be documented under both STYLE and CLASS as things have
> been getting reworked in this area of the code. I player with setting
> MAXSIZE and that seems to work as expected, but I think MINSIZE is broken. I
> check it on both 5.6.5 and 5.6.6.
> I can write it up as a bug tomorrow.
> -Steve W
>> -Jukka Rahkonen-
>> Stephen Woodbridge wrote:
>>> Hi All,
>>> Thomas maybe you know this?
>>> I have a layer:
>> SYMBOL
>> NAME "dots"
>> TYPE SIMPLE
>> STYLE 1 3 END
>> END
>> LAYER
>> NAME "World Admin-1 Z1"
>> GROUP "cb"
>> STATUS DEFAULT
>> TYPE LINE
>> DATA "not-nt2/10m-admin-1-states-provinces-lines-shp"
>> PROJECTION "init=epsg:4326" END
>> MAXSCALEDENOM 50000000
>> MINSCALEDENOM 5000000
>> CLASS
>> STYLE
>> COLOR "#aaaaaa"
>> SYMBOL "dots"
>> WIDTH 1
>> MINSIZE 8000.0
>> END
>> END
>> END
>>> MapServer version 5.6.6 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
>> OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=ICONV
>> SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
>> SUPPORTS=WFS_SERVER SUPPORTS=RGBA_PNG INPUT=EPPL7 INPUT=POSTGIS
>> INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
>>> I can not get any of these lines to turn off. I have tried, variations
>> of large MINSIZE values, commenting out the SYMBOL, using SIZE or WIDTH.
>> No value of MINSIZE seems to have any impact. A large number of the
>> lines are under 5 pixels at the scale I'm using 28M. The lines display
>> fine I just need to turn off the short ones to declutter the image.
>>> I spent all night on this with no success so I guess its time to ask.
>> -Steve W
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
