[mapserver-users] mapscript php with agg rendering?
Michael Schulz
mandschulz at googlemail.com
Tue Feb 15 08:56:07 EST 2011
yeah, unfortunately I tried that one already, but it didn't work
either. Although "IMAGETYPE aggpng24" now shows up in the saved
mapfile, but the rendered output is still definitely GD and not AGG.
I found this in trac http://trac.osgeo.org/mapserver/ticket/2813, it's
a bit old but that seems exactly my problem, only the solution doesn't
workforme.
Thx, Michael
2011/2/15 Pavel Iacovlev <iacovlev.pavel at gmail.com>:
> Use the predefined one:
> $map->selectOutputFormat('AGGPNG24');
> On Tue, Feb 15, 2011 at 1:37 PM, Michael Schulz <mandschulz at googlemail.com>
> wrote:
>> Hi mapservers,
>> I have a question regarding the AGG rendering when creating a map
>> completly from php-mapscript. In the script I (think I) am setting all
>> the required parameters for the map to be rendered with AGG using
>> 24bit:
>> $oMap=ms_newMapObjFromString("MAP END");
>> $oMap->outputformat->set('name','png');
>> $oMap->outputformat->set('driver','AGG/PNG');
>> $oMap->outputformat->set('mimetype','image/png');
>> $oMap->outputformat->set('imagemode',MS_IMAGEMODE_RGBA);
>> $oMap->outputformat->set('extension','png');
>> $oMap->outputformat->set('transparent',MS_TRUE);
>> I've experienced for some time with the following directive, trying to
>> actually invoke the correct outputformat
>> $oMap->selectoutputformat("png");
>> But to no avail. The maps that derive from this script clearly use the
>> GD driver. When I saved the generated map-file to the filesystem I
>> found the following line in the map section:
>> IMAGETYPE gif
>> I am using MapServer, Mapscript 5.6.6., PHP 5.3.3 on OpenSuse 11.3
>> Maybe someone could share some mapscript code or has some hints how to
>> actually return AGG rendered maps.
>> Thanks, Michael
>> Michael Schulz
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
Michael Schulz
Christoph-Mang-Str. 5
D-79100 Freiburg
