[mapserver-users] formatting in HTML templates
David Hildebrand
David.Hildebrand at afsc.ca
Tue Feb 15 14:41:01 EST 2011
This may be slightly off the MapServer topic but my problem is related
to a MapServer implementation.
I am retrieving the date and time from the shapefile DBF of my layer in
the following format (yymmddhhmmss). The string represents the UTC time
of satellite image acquisition. I want to convert that to local time
and express it as a normal date string (e.g.: July 8, 2009 10:45:25 AM).
I'm thinking I can do that with PHP code embedded in the template. I
know my server has PHP support but when I try to embed a simple 'Hello
world' in the template it seems to be ignored. Would it be better
define a URL to the PHP code (in stead of a template) and then build the
entire HTML page dynamically?
Thanks.
David V. Hildebrand
Agriculture Financial Services Corporation
(403) 782-8239
www.afsc.ca <about:www.afsc.ca> <http://www.afsc.ca
<http://www.afsc.ca/> >
This communication is intended for the use of the recipient to which it
is addressed, and may contain confidential, personal and/or privileged
information. Please contact Agriculture Financial Services Corporation
immediately if you are not the intended recipient of this communication,
and do not copy, distribute, or take action relying on it. Any
communication received in error, or subsequent reply, should be deleted
or destroyed. Please consider the environment before printing this
email.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110215/d4efdaa6/attachment.html
