[mapserver-users] Re: Projection library error - EPSG Issue
phil7g
phil7g at gmx.net
Thu Feb 17 05:11:34 EST 2011
Hi there!
Everything I get back when adding debugging is this
http://gis-test.geomatik.rub.de/cgi-bin/mapserv?map=/srv/www/htdocs/GIS2/Studieren_in_Bochum.map&mode=map
, which isn't very helpful... Does the error-logfile contain more
information? Unfortunately, I'm not the admin of the server and I had some
problems with using the mode that produces an error-logfile. I've just addes
these lines:
CONFIG "MS_ERRORFILE" stdout
DEBUG 5
CONFIG "PROJ_DEBUG" "ON"
CONFIG "CPL_DEBUG" "ON"
best regards!
Phil
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Projection-library-error-EPSG-Issue-tp6007730p6035311.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
