[mapserver-users] Re: Projection library error - EPSG Issue
Frank Warmerdam
warmerdam at pobox.com
Thu Feb 17 10:00:10 EST 2011
On 11-02-17 05:11 AM, phil7g wrote:
> Hi there!
> Everything I get back when adding debugging is this
> http://gis-test.geomatik.rub.de/cgi-bin/mapserv?map=/srv/www/htdocs/GIS2/Studieren_in_Bochum.map&mode=map
> , which isn't very helpful... Does the error-logfile contain more
> information? Unfortunately, I'm not the admin of the server and I had some
> problems with using the mode that produces an error-logfile. I've just addes
> these lines:
> CONFIG "MS_ERRORFILE" stdout
> DEBUG 5
> CONFIG "PROJ_DEBUG" "ON"
> CONFIG "CPL_DEBUG" "ON"
> best regards!
> Phil
Phil,
I suspect the problem is not finding the epsg init file. CPL_DEBUG output
will go to stderr which would go into the Apache error logfile.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
