[mapserver-users] RE: polygon tool
Tom van der Putte
tom at vdputte.nl
Fri Feb 18 02:37:39 EST 2011
Hi
Bob,
You could also try using Fusion, it also has a polygon tool in
there, but again its based on Open Layers. I gues you can make your
own, but you'd need some sort of framework that converts the drawn
polygon to the location, projection and units that your basemap is in,
for which openLayers is the perfect framework I think.
Tom van der Putte
From: mapserver-users-bounces at lists.osgeo.org [1]
[mapserver-users-bounces at lists.osgeo.org [2]] On Behalf Of Bistrais,
Bob
Sent: Thursday, February 17, 2011 8:18 AM
To: mapserver-users
Subject: [mapserver-users] polygon tool
I am trying to create a polygon tool with PHP MapScript and
JavaScript.
I
used to select map features. This kind of thing probably has been
done
before. Can anyone direct me to some code samples?
Links:
[1] mailto:mapserver-users-bounces at lists.osgeo.org
[2] mailto:mapserver-users-bounces at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110218/0f9365ba/attachment.html
