[mapserver-users] TEMPLATE generation completion (NOT!)
Bob Basques
Bob.Basques at ci.stpaul.mn.us
Fri Feb 18 10:27:02 EST 2011
All,
I've been chasing this one around for a day now.
For some reason (might be a part of our funky configuration too, but ) a TEMPLATE "FOOTER" will not get pasted to the bottom of the output.
The HEADER and RECORD values populate just fine, I have many (MANY) other layers in the same configuration that work just fine as well.
My question, anyone got and ideas about why a FOOTER template chunk will not populate on a MapServer request?
I've looked at:
* Permissions on the file (same as all others)
* Content of TEMPLATE chunk (it only contains "</imagemap>" ), I even recreated it a couple of times manually.
* I checked the mapfile (but everything else works, the legend, the image output, the HEADER and RECORD output . . .
* The data is even popping out in the IMAGEMAP correcrtly.
* Moved around the map with different areas of interest, different numbers of returned records.
Thanks (from bewildered!!)
bobb
Here is the MAPFILE and TEMPLATES:
MAP
NAME 'RSVP'
EXTENT 573387 162092 574211 162555
STATUS ON
SYMBOLSET inventory.symbols
FONTSET RESOURCES/inventory.fonts
TRANSPARENT TRUE
IMAGETYPE PNG
LAYER
METADATA
"ows_title" "Surface Class"
"gml_include_items" "all"
"qstring_validation_pattern" "."
"fido_search_items" ""
"fido_search_titles" ""
END
NAME 'SURFACE CLASS'
GROUP 'SURFACE CLASS'
DATA 'DATA/Surface_Class'
STATUS DEFAULT
TYPE POLYGON
CLASSITEM 'GRIDCODE'
CLASS
NAME 'Tree Canopy'
EXPRESSION /1/
COLOR 38 94 0
OUTLINECOLOR 100 100 100
END
CLASS
NAME 'Turf/Grass'
EXPRESSION /2/
COLOR 203 214 139
END
CLASS
NAME 'Bare Soil'
EXPRESSION /3/
COLOR 168 112 0
END
CLASS
NAME 'Water'
EXPRESSION /4/
COLOR 151 219 242
END
CLASS
NAME 'Buildings'
EXPRESSION /5/
COLOR 92 43 0
END
CLASS
NAME 'Impervious Surface'
EXPRESSION /6/
COLOR 78 78 78
END
TEMPLATE './TEMPLATES/surface_class_record.xml'
HEADER './TEMPLATES/surface_class_header.xml'
FOOTER './TEMPLATES/surface_class_footer.xml'
END
END
Header
<?xml version="1.0"?>
<imagemap>
<error message="[errmsg_esc]"/>
<style name="Inventory">
<title>
<attr name="background" value="black"/>
<attr name="fontWeight" value="bold"/>
<attr name="color" value="white"/>
</title>
<contents>
<attr name="background" value="white"/>
</contents>
</style>
Record
<popup class="Inventory" shape="poly" coords="[shpxy xf="," proj=image],10"
ground="[shpxy]">
<title>Surface Classification</title>
<item title="Grid Code:">[GRIDCODE]</item>
</popup>
Footer -- (OUTPUT BREAKS HERE!!!)
</imagemap>
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110218/484f66cd/attachment-0001.html
