[mapserver-users] problem of legend icon for pixmap-filling	type	polygon layer
    Lime, Steve D (DNR)
    Steve.Lime at state.mn.us
    Fri Feb 18 07:55:21 PST 2011
I can confirm the issue. Not sure what's going on but something's broken in the legend generation. I'll try and sum
things up and file a ticket against 5.6. We won't patch back to 5.0 for something like this.
As a workaround you might consider setting a KEYIMAGE in your class definition. Make it the same size as your legend
"chips" (usually something like 25x15) and that image will be used instead of creating one dynamically. I tried that
here and it seems to work. You should be able to clip a section of a MapServer-created map out for this purpose.
Steve
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Isao NASUNO
Sent: Thursday, February 17, 2011 6:29 PM
To: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] problem of legend icon for pixmap-filling type polygon layer
Hello Steve,
I am using gd-2.0.33, with MapServer 5.0.2.
Thank you,
Isao
(2011/02/18 6:54), Lime, Steve D (DNR) wrote:
> Which driver are you using (AGG or GD)? I'll run some tests here and report back... Steve
> Sent: Wednesday, February 16, 2011 11:20 PM
> Subject: [mapserver-users] problem of legend icon for pixmap-filling type polygon layer
> Hello all,
> I had send same question 2 weeks ago but I have no response,
> so I try again with more detail of the problem.
> ** situation **
> I'm trying to make pixmap-filled polygon maps and I did it without problem,
> however a problem in getting legend.
> I want legend icons by mapserver cgi with request "mode=legend" like following.
> (base pattern)    (what I want)
>                    oxoxoxoxoxox
>                    xoxoxoxoxoxo
> oxox              oxoxoxoxoxox
> xoxo    ------>    xoxoxoxoxoxo
> However I get following. It is like a legend icon of line layer.
>       oxox    oxox
>      oxoxox  oxoxo
>     oxoxoxoxoxoxo
>    oxoxo oxoxoxo
>   oxoxo   oxoxo
>   xoxo    xoxo
> ** version **
> I'm using MapServer 5.0.2 on CentOS 5.2.
> I also try MapServer 5.6.x (forgot for detail), but the situation is same.
> ** what I did **
> The symbol is defined like ...
>    SYMBOL
>      NAME "symbol1"
>      TYPE pixmap
>      image /somewhere/symbol1.gif
>      transparent 1
>    END
> The layer is as following...
>    layer
>     name "jimon"
>     connectiontype postgis
>     connection "user=db password=xxxxxxx dbname=DB host=localhost port=5432"
>     data "the_geom from polygon"
>     status on
>     type polygon
>     classitem "id"
>     projection
>      "init=epsg:4326"
>     end
>     class
>      name "pattern1 "
>      expression "1"
>      style
>        symbol "symbol1"
>      end
>     end
>    end
> Could anyone please help me !?
> Isao
More information about the MapServer-users
