[mapserver-users] Spherical Mercator Projection Problem
Jean-François Gigand jean-francois at gigand.fr
Thu Feb 24 12:33:00 PST 2011
Indeed.
Also note that EPSG:900913 is the same as EPSG:3785 and EPSG:3857.
These three are the Spherical Mercator projection, which is the right
one to use for overlays on Google Maps.
2011/2/24 Fawcett, David (MPCA) <David.Fawcett at state.mn.us>:
> Sergey,
> If your data is in epsg:4326 and you want to publish the data as epsg:3785,
> you will need to projection blocks to your layers.
> Something like:
>   PROJECTION
>             "init=epsg:4326"
>   END
> The Projection block in the MAP section defines your output projection.
> Because your data is not in the same projection, you will need to define a
> projection block in each layer section.  Those projection blocks define the
> ‘input’ projection.  They tell MapServer what projection the data exists
> in.  This allows MapServer (with proj4 support) to re-project your data to
> the output projection.
> David.
> From: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Sergey Kraev
> Sent: Wednesday, February 23, 2011 5:01 AM
> To: mapserver-users at lists.osgeo.org
> Subject: [mapserver-users] Spherical Mercator Projection Problem
> Hi,
> I’m running MS4W v3.0 (including MapServer 5.6.5) on Windows.
> My data source are PostGIS multipolygon countries’ borders.
> I have successfully got MapServer to render the world map in WGS84
> projection using these settings:
> Request:
> http://127.0.0.1:8080/cgi-bin/mapserv.exe?map=world.map&mode=map&mapsize=256+256&mapext=-180+-90+180+90
> world.map:
> MAP
> EXTENT                   -180 -90 180 90
>   #EXTENT         -20037508 -20037508 20037508 20037508
>   SIZE           256 256
>   IMAGECOLOR     153 179 204
>   FONTSET        "c:\MS4W\fonts\fonts.list"
>   RESOLUTION        96
>   MAXSIZE        5000
>   PROJECTION
>             "init=epsg:4326"
>             #"init=epsg:3785"
>   END
> <layers don’t have PROJECTION sections>
> I would like MapServer to render the same data into a “Web (spherical)
> Mercator” projected map (epsg:3785), but I don't know how to modify my
> request and mapfile in order to get the correct map.
> With the following settings I just receive a picture without any polygons.
> \ms4w\proj\nad\epsg:
> <3785> +proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0
> +y_0=0 +k=1.0 +units=m +nadgrids=@null +wktext  +no_defs <>
> Request (only mapext is different):
> http://127.0.0.1:8080/cgi-bin/mapserv.exe?map=world.map&mode=map&mapsize=256+256&mapext=-20037508+-20037508+20037508+20037508
> world.map (only EXTENT and PROJECTION are different):
> MAP
>   #EXTENT                -180 -90 180 90
>   SIZE           256 256
>   RESOLUTION        96
>   MAXSIZE        5000
>   PROJECTION
>             #"init=epsg:4326"
>             "init=epsg:3785"
>   END
> I’m assuming that -20037508 -20037508 20037508 20037508 is correct extent
> for the whole world map, since Google uses that and they also have Mercator
> projection.
> Thanks for your help.
> Sergey
More information about the MapServer-users mailing list
