[mapserver-users] Re: Raster dataset recommendations
Mark Korver
mwkorver at gmail.com
Fri Feb 25 10:31:12 EST 2011
If you are merging tiles together to create 1 large tif, why would you
need to create an index to it? I would think you would just directly
reference the tif.
so, rather than
TILEINDEX ../data/myindex
skip the index building steps
just
DATA ../data/big.tif
On Fri, Feb 25, 2011 at 9:08 AM, Edi.Karadumi <edikaradumi at gmail.com> wrote:
> Since it as less than 4gb, if you have the image in different tiles just
> merge them together. The image format should be tif.
> 1- Fisrt enable internal tiling with the command
> gdal_translate -co "TILED=YES" original.tif tiled.tif
> 2-than add overviews
> gdaladdo -r average 2 4 8 16 32 64 128
> 3-create a tileindex
> gdaltindex myindex.shp *.tif
> 4-than create a spatial index
> shptree myindex.shp
> and finally add the layer to the map
> LAYER
> NAME myorthos
> TYPE RASTER
> DUMP TRUE
> STATUS ON
> TILEITEM Location
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Raster-dataset-recommendations-tp6064491p6064777.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org
