[mapserver-users] Re:REST and SOAP in Mapserver
Robert Hollingsworth
reh2 at prodigy.net
Fri Feb 25 13:48:27 EST 2011
Eric,
Several years ago I did some experimental
work with SOAP and REST inside the mapserv
engine. The archives may contain a few old
messages about the details, but what I was doing
was to consume (now defunct) ESRI ArcWeb
Services map images as raster backdrops for
added mapserver vector layers. I created
CONNECTIONTYPE ARCWEB and associated
mapserver mapfile constructs to ArcWeb
params.
The communication part was fairly easy to deal with:
I refit the existing OWS cURL code to access the ESRI
server. The construction of the SOAP xml was
cumbersome. The image that came back was slipped
into the existing raster output mechanism.
When I revisited the project a year or so later, I decided
it was best to stay OUT of mapserv cgi and opt instead
for doing the work in php-mapscript, where the SOAP
processing is more advanced.
Also, as I see it, the main problem of trying to consume
SOAP and REST services in mapserver is simply that it
is difficult to anticipate what kinds of functions you are
going to be using to access the SOAP/REST server, so
there's no generic way to associate mapfile constructs to
the foreign parameters, and there's no way to make the
construction of SOAP/REST requests generic either.
If someone REALLY needed to do this within mapserv cgi,
there might be some way to have WSDL-processing to
make things more generic, but I'd be skeptical about the
success of such a venture.
Robert H.
original message:
To: mapserver-users at lists.osgeo.org
Is it possible to consume REST and/or SOAP services
in Mapserver somewhat like WMS and how?
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110225/128bb9ef/attachment.html
