[mapserver-users] GDAL input formats
Brent Fraser
bfraser at geoanalytic.com
Thu Jan 6 18:42:08 EST 2011
David,
I'd recommend converting your floating point images to 24-bit RGB
images (as long as you can afford the disk space). You'd have to
configure mapserver (see SCALE in
http://mapserver.org/input/raster.html#bit-rgb-rendering) to do this on
the fly anyway as browsers don't know what to do with floating point
images.
You can use gdal_translate to do the conversion (see "-scale" in
http://www.gdal.org/gdal_translate.html).
Best Regards,
Brent Fraser
On 1/5/2011 2:46 PM, David Hildebrand wrote:
> My question now relates to output.
> David V. Hildebrand
> Agriculture Financial Services Corporation
> (403) 782-8239
> -----Original Message-----
> From: Alexander Petkov [mailto:greenkov at gmail.com]
> Sent: Wednesday, January 05, 2011 2:07 PM
> To: David Hildebrand
> Cc: Rahkonen Jukka; mapserver-users at lists.osgeo.org
> Subject: Re: [mapserver-users] GDAL input formats
> Hi David:
> If gdal can read your rasters (gdalinfo will work for a quick and easy
> test), mapserver will too.
> Alex
> On Wed, Jan 5, 2011 at 1:46 PM, David Hildebrand
> <David.Hildebrand at afsc.ca> wrote:
>> Thanks, Jukka. The second part of my question relates to floating point
>> images. I don't think that MapServer can handle 3-band floating point
>> images because I can't seem to find anything in the documentation and I
>> have tried a couple of things that don't work. I suppose the best thing
>> would be to convert them to 3-band, 8-bit images.
>> David V. Hildebrand
>> (403) 782-8239
>> From: Rahkonen Jukka [mailto:Jukka.Rahkonen at mmmtike.fi]
>> Sent: Wednesday, January 05, 2011 10:07 AM
>> Cc: mapserver-users at lists.osgeo.org
>> Hi,
>> Have you already read the ENVI part of the following document?
>> http://gdal.org/frmt_various.html#ENVI
>> -Jukka Rahkonen-
>>> Frank:
>>> As you are probably aware, ENVI image files are associated with a
>> header
>> file which has a "hdr" extension. The extension of the actual image
>> file can be anything but the root name of the image file and header file
>> must be the same. If I specify the HDR file on the DATA line of my map
>> file there may be more than one file in the same workspace which are
>> candidate image files. If I specify the name of the image file, which
>> can have any or no extension, I don't see how the system can figure out
>> the format. Is there a particular extension which is assumed by GDAL
>> for the image file?
>>> Thanks.
>> David V. Hildebrand
>> (403) 782-8239
>> From: mapserver-users-bounces at lists.osgeo.org
>> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Frank
>> Warmerdam
>> Sent: Tuesday, January 04, 2011 5:33 PM
>> To: mapserver-users at lists.osgeo.org
>> On 11-01-04 03:14 PM, David Hildebrand wrote:
>>> I'm wondering how to specify a particular GDAL format. I have some
>>> 3-band floating point images in ENVI format and I would like to retain
>>> that format because I have GDAL support. Secondly, would it be better
>>> to convert them to GeoTiff files? Would it also be better to scale
>> them
>>> to, say 16-bit signed integer files?
>> David,
>> I searched back a bit in the archive, but I couldn't find any leadup
>> discussion to the above. It seems to lack context.
>> So, you have 3band floating point images in ENVI format and you would
>> like to retain that format. Is there something holding you back?
>> You said you don't know "hjow to specify a particular GDAL format". Do
>> you mean when you are generating output via GDAL such as with WCS? Or
>> do you mean how you tell MapServer what format an input file is in?
>> You don't have to tell MapServer (or GDAL) what format a file is in.
>> It figures it out - assuming it is a supported format.
>> Does that help?
>> Best regards,
>> I set the clouds in motion - turn up | Frank Warmerdam,
>> warmerdam at pobox.com
>> light and sound - activate the windows | http://pobox.com/~warmerdam
>> and watch the world go round - Rush | Geospatial Programmer for Rent
