[mapserver-users] SQL Server 2008 layer only partially displaying
Milena
mgebreab at maxgeo.com
Sun Jan 9 19:43:58 EST 2011
Hi all,
I have been trying to display a WMS layer from a SQL server database. Now, I
managed successfully to connect to the database and some part of the layer
appeared when Getmap requested but not all the polygons I should be seeing.
The strange thing is every time I refresh the request different parts of the
layer appear. Does anybody know why this might be? Also if I remove the
Class from the Layer, nothing is displayed. Map detail below
Thanks!
Milen
MAP
NAME Spatial
IMAGECOLOR 0 255 255
SIZE 600 800
IMAGETYPE png
PROJECTION
"init=epsg:4326" #latlon on WGS84
END
EXTENT 100.000000 -35.000000 129.000000 -11.000000
# lon/lat extents of WA tenements
WEB
IMAGEPATH "/tmp/ms_tmp/"
IMAGEURL "/ms_tmp/"
METADATA
"map" "C:/ms4w/apps/Spatial/config.map"
"ows_schemas_location" "http://schemas.opengeospatial.net"
"ows_title" "Sample WMS"
"ows_abstract" "Sample WMS of Spatial"
"ows_keywordlist" "Spatial,WMS,Maxwell"
"ows_onlineresource"
"http://localhost:8080//spatial?map=C:/ms4w/apps/Spatial/config.map&"
"wms_srs" "EPSG:4326" #latlon
"wms_feature_info_mime_type" "text/plain"
"wms_feature_info_mime_type" "text/html"
"wms_server_version" "1.1.1"
"wms_formatlist" "image/png,image/gif,image/jpeg"
"wms_format" "image/gif"
END #metadata
END #web
LAYER
NAME "tenements"
CONNECTIONTYPE PLUGIN
PLUGIN "C:/ms4w/Apache/specialplugins/msplugin_mssql2008.dll"
CONNECTION "Server=.\SQL_2008;Database=LeaseCDemo2008GIS;Integrated
Security=true"
DATA "geom from dbo.WA_Tenements USING UNIQUE ID USING SRID=0"
TYPE POLYGON
STATUS DEFAULT
METADATA
"ows_title" "tenements"
END #metadata
PROJECTION
"init=epsg:4326"
END
EXTENT 100.000000 -35.000000 129.0000000 -11.00000000
TOLERANCE 0
MAXSCALE 100000000
CLASS
NAME "tenements"
STYLE
COLOR 255 235 190
OUTLINECOLOR 0 0 0
END #style
END #class
END #Layer
End #Map
View this message in context: http://osgeo-org.1803224.n2.nabble.com/SQL-Server-2008-layer-only-partially-displaying-tp5905621p5905621.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
