[mapserver-users] Labels are cut at the borders of the tiles
thomas bonfort
thomas.bonfort at gmail.com
Mon Jan 10 10:46:51 EST 2011
it does not seem to be documented.
when set to "ON", what happens is that labels are fixed to a
geographical location on the feature, instead of being adjusted to fit
in the pixel range of the created map. this is essentially used for
tiling, as in that case each feature will be labeled exactly once,
instead of once per tile.
thomas
On Mon, Jan 10, 2011 at 16:34, Niccolo Rigacci <niccolo at rigacci.org> wrote:
> On Mon, Jan 10, 2011 at 10:43:22AM -0400, Jeff McKenna wrote:
>> PROCESSING "LABEL_NO_CLIP=1"
> Please, do you know if that directive is documented somewhere?
> I searched www.mapserver.org (with the Quick search box and with
> Google), but nothing is found.
> Niccolo Rigacci
> Firenze - Italy
> mapserver-users at lists.osgeo.org
