[mapserver-users] Labels are cut at the borders of the tiles
Wim Vanbelle
wimvanbelle at gmail.com
Tue Jan 11 03:29:40 EST 2011
Thanks for clearing that out Thomas. We were having similar issues here.
Is there a similar setting for linestring drawing? Eg when using pixel
offset the lines get cut off at the end of the tiles.
This is resolved using the gutter parameter in openlayers as you have
mentioned, but is still a problem for google and bing maps.
thanks.
On 10 January 2011 16:46, thomas bonfort <thomas.bonfort at gmail.com> wrote:
> it does not seem to be documented.
> when set to "ON", what happens is that labels are fixed to a
> geographical location on the feature, instead of being adjusted to fit
> in the pixel range of the created map. this is essentially used for
> tiling, as in that case each feature will be labeled exactly once,
> instead of once per tile.
> thomas
> On Mon, Jan 10, 2011 at 16:34, Niccolo Rigacci <niccolo at rigacci.org>
> wrote:
> > On Mon, Jan 10, 2011 at 10:43:22AM -0400, Jeff McKenna wrote:
> >> PROCESSING "LABEL_NO_CLIP=1"
> > Please, do you know if that directive is documented somewhere?
> > I searched www.mapserver.org (with the Quick search box and with
> > Google), but nothing is found.
> > Niccolo Rigacci
> > Firenze - Italy
> > mapserver-users mailing list
> > mapserver-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110111/f5a3e29c/attachment.html
