[mapserver-users] How would I modify a map file so that whena
getcapabilities is run it outputs as tiled layers (wms-t)
includinglisting resolutions listed below:
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Tue Jan 11 11:42:52 EST 2011
Just guessing, but sending resolutions with GetCapabilities could make sense for example with a client like uDig which can cache WMS-C tiles locally. The WMS calls uDig sends in this case are just plain WMS requests and Mapserver would handle them nicely. Perhaps John would like to do something similar.
One alternatively might be to use a local, edited GetCapabilities document instead of letting Mapserver to create it on-the-fly.
-Jukka Rahkonen-
-----Alkuperäinen viesti-----
Lähettäjä: mapserver-users-bounces at lists.osgeo.org puolesta: Yewondwossen Assefa
Lähetetty: ti 11.1.2011 18:05
Vastaanottaja: John Mitchell
Kopio: mapserver-users at lists.osgeo.org
Aihe: Re: [mapserver-users] How would I modify a map file so that whena getcapabilities is run it outputs as tiled layers (wms-t) includinglisting resolutions listed below:
Not sure I understand well the question: Mapserver does not support
tiled layers by itself. Usually when doing tiles, you will use tilecache
servers (tilecache.org, or mode-geocache
http://code.google.com/p/mod-geocache/ ) that can be set up to
possibly use MapServer as rendering engine .
Wehn you mention getcapabilities, are referring to the getcapabilities
support in the WMTS (web map tiling service from OGC)? If that is the
case, I would recommend again to check the tilecache libraries
mentioned above.
If this does not reflect what you intend to accomplish, please give more
details on what you expect from MapServer.
best regards,
On 11/01/2011 10:15 AM, John Mitchell wrote:
> How would I modify a map file so that when a getcapabilities is run it
> outputs as tiled layers (wms-t) including listing resolutions listed
> below:
> <Resolutions>
> 0.703125,0.3515625,0.17578125,0.087890625,0.0439453125,0.02197265625,0.010986328125,0.0054931640625,0.00274658203125,0.001373291015625,6.866455078125E-4,3.4332275390625E-4,1.71661376953125E-4,8.58306884765625E-5,4.291534423828125E-5,2.1457672119140625E-5,1.0728836059570312E-5,5.364418029785156E-6,2.682209014892578E-6,1.341104507446289E-6,6.705522537231445E-7,3.3527612686157227E-7
> </Resolutions>
> Thanks,
> John
> John J. Mitchell
Assefa Yewondwossen
Software Analyst
Email: yassefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
