[mapserver-users] mapserver defunct
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Wed Jan 12 08:19:35 EST 2011
Maybe my experience is somehow related. I have just been seeding GeoWebCache from our Mapserver this week and using more than two threads with Apache fast-cgi proved to be very unreliable. Some of the GWC threads were dying soon with message:
ERROR [seed.MTSeeder] - Unexpected response code from backend:
500 for http://....
I turned back to normal Mapserver cgi and seeding is progressing much faster for me now because I can keep more GeoWebCache seeder threads up this way.
-Jukka Rahkonen-
thomas bonfort wrote:
> http://trac.osgeo.org/mapserver/ticket/3099 might be related. I don't
> know how fastcgi in lighty works, but mapserver in fastcgi definitely
> does not play nicely with fastcgi implementations that don't expect
> child processes to ever exit().
> As Stpehen pointed out, I'd try with apache/fastcgi , if not only to
> confirm that the problem is in the fastcgi rather than pure mapserver
> side.
> best regards,
> thomas
> On Wed, Jan 12, 2011 at 13:23, Wim Vanbelle
> <wimvanbelle at gmail.com> wrote:
> > The problem definately seems related to concurrency.
> > Load benching using 1 concurrent requests: 0 fails.
> > Load benching using 2 concurrent requests: +- 30% fails
> > more concurrent = more fails.
> > The failed seem to return with HTTP 500.
> > Running a shp2img during this time, still returns a good image.
> > I'll post more info about this topic and a resolution, if i
> find one :). Do
> > note that we're dealing with shapefiles with 3 000 000
> linestrings. While
> > they consist only of 2 coordinates (begin end obviously),
> it's still a big
> > thing to load.
> > On 12 January 2011 06:18, Stephen Woodbridge
> <woodbri at swoodbridge.com>
> > wrote:
> >> Wim,
> >> I'm not sure I have any magic bullet for this problem,
> because I'm not
> >> sure what is causing it. If this was my project, I would
> tackle it like
> >> this:
> >> 1. alert people we have a problem that might impact the
> release date if
> >> you have not already done that
> >> 2. divide the problem to try and localize what is causing it
> >> a. do the tiles that fail, always fail? this points at a potential
> >> mapserver related issue as opposed to a load issue
> >> a.1 have you turned on mapfile DEBUG output? can you
> identify the layer
> >> a.2 you can get some maybe useful output from:
> >> strace /path/to/mapserv QUERY_STRING='<url arguments>'
> >> gdb /path/to/mapserv
> >> run QUERY_STRING='<url arguments>'
> >> where
> >> quit
> >> valgrind /path/to/mapserv QUERY_STRING='<url arguments>'
> >> a.3 you can run it with shp2img ...
> >> b. is it fastcgi, do you see the same problem if you build
> it as cgi
> >> c. is it lighttpd, do you see the same problem if you run
> it with apache
> >> fastcgi? what about apache cgi?
> >> Intermittent problems are the hardest to diagnose because
> they often are
> >> not reproducable in a debuging environment. We might be
> able to help you
> >> with more information.
> >> I have done a lot of load testing on various versions of
> mapserver and
> >> tiled all of US and Canada about 4-5 different times using
> mapserver. I have
> >> not used FastCGI/Lighty and lighttpd, so I'm not sure
> about what influence
> >> that might have on the problem.
> >> Hope this gives you some ideas.
> >> Best regards,
> >> -Steve W
> >> http://imaptools.com/
> >> On 1/11/2011 3:15 PM, Wim Vanbelle wrote:
> >>> Well, the problem is that the requests are not always served.
> >>> During load testing, say about 10 concurrent requests I
> also load the
> >>> map. But there are randomly tiles that are never loaded.
> I thought this
> >>> would be related to the defunct processes, but that is
> not a certainty.
> >>> My setup is lighttpd + fastcgi.
> >>> To be honest I'm in a pretty bad situation now,
> considering we go live
> >>> with this in 9 days.
> >>> Not sure what else I can do honestly.
> >>> On 11 January 2011 19:05, Stephen Woodbridge
> >>> <mailto:woodbri at swoodbridge.com>> wrote:
> >>> Here is an explanation of defunct processes:
> >>> http://www.webmasterworld.com/forum40/1032.htm
> >>> I'm sure there are others. So since you are running
> fastcgi, it is
> >>> the responsibility of the fastcgi parent process to
> clean up dead
> >>> child processes. It is likely that it is busy because
> you are doing
> >>> load testing or there is some subtle issue that is
> occurring. If you
> >>> are getting good responses from mapserver, you
> probably do not need
> >>> to worry about it unless you are getting tons of them.
> >>> If you are using apache, I believe there is a
> parameter that you can
> >>> set for fastcgi processes which will let them die
> after N requests.
> >>> This should clean those up and apache will spawn a new
> process if
> >>> needed to replace the that died.
> >>> -Steve W
> >>> On 1/11/2011 10:04 AM, Wim Vanbelle wrote:
> >>> Hi all,
> >>> I'm getting a lot of
> >>> 27098 x 20 0 0 0 0 Z 1 0.0
> 0:00.03 mapserv
> >>> <defunct>
> >>> 27104 x 20 0 0 0 0 Z 1 0.0
> 0:00.03 mapserv
> >>> <defunct>
> >>> while load testing mapserver. Is there any way I
> can go about
> >>> checking
> >>> out why this is happening? Especially when doing
> concurrency
> >>> tests it
> >>> seems to go sideways.
> >>> Currently i'm using :
> >>> MapServer version 5.6.5 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
> >>> OUTPUT=WBMP
> >>> OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG
> SUPPORTS=FREETYPE
> >>> SUPPORTS=ICONV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER
> >>> SUPPORTS=WMS_CLIENT
> >>> SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER
> >>> SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS
> >>> SUPPORTS=GEOS
> >>> SUPPORTS=RGBA_PNG INPUT=EPPL7 INPUT=POSTGIS
> INPUT=OGR INPUT=GDAL
> >>> INPUT=SHAPEFILE
> >>> using FastCGI/Lighty.
> >>> Do note that the mapfile itself seems to be fine,
> since it does
> >>> render
> >>> content when i'm the single user using it.
> >>> Thanks for your expert insight :D.
> >>> _______________________________________________
> >>> mapserver-users mailing list
> >>> mapserver-users at lists.osgeo.org
> >>> <mailto:mapserver-users at lists.osgeo.org>
> >>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
