[mapserver-users] Reporting lat/long from projected map units
Bistrais, Bob
Bob.Bistrais at maine.gov
Thu Jan 13 10:43:53 EST 2011
I downloaded the code and am looking at the Wiki. I don't see anything
to input screen or UTM coords. Is it in the code somewhere?
From: Milo van der Linden [mailto:milo at dogodigi.net]
Sent: Wednesday, January 12, 2011 12:44 PM
To: mapserver-users
Subject: Re: [mapserver-users] Reporting lat/long from projected map
units
(Sorry, my last posts went straight to you by accident, I prefer to stay
on the list, but gmail for applications not always agrees with me)
proj4js has project pages including documentation on the OSGeo wiki. The
userguide is here:
http://trac.osgeo.org/proj4js/wiki/UserGuide
and it immediately explains what you want
2011/1/12 Bistrais, Bob <Bob.Bistrais at maine.gov>
Yes, I can get UTM coordinates back. Can you elaborate a bit on
proj4js? I'm not familiar with that.
Sent: Wednesday, January 12, 2011 11:10 AM
To: Bistrais, Bob
units
Well then one question remains:
Are you able to convert screen coords to UTM capturing an onclick event?
Because then all you need to do is enhance it with proj4js
Yes, a web mapping application. Not using Open Layers. We are using
PHP-Mapscript/HTML/JavaScript. All queryable data is in shapefiles,
again, all of these are in UTM.
Sent: Wednesday, January 12, 2011 11:03 AM
To: Bistrais, Bob
units
Are you talking bout a web-app? Do you use a client like OpenLayers?
What programming language(s) do you use? Is your datasource a database?
Like postgis?
If you can get UTM coordinates from the mouseclick, the next best option
(in my opinion) would be to use proj4js:
http://proj4js.org/
Simply embed the js-library ad an event for mouse handling and convert:
screen->utm->4326.
This should be fairly straightforward, but I was wondering what is the
easiest and quickest way to convert coordinates on the fly. All my data
is in UTM coordinates. I want to report coordinates to the screen in
Lat/Long. Changing the projections on the map files to lat/long
(EPSG:4326) is not an option, as this will cause problems elsewhere. So
what I want to do is take point coordinates, either from a mouse click
or from UTM coordinates, project to lat/long, which will be reported in
a result window. What is the quickest way to do this?
mapserver-users mailing list
mapserver-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110113/c50eab27/attachment-0001.html
