[mapserver-users] Z_BEST_COMPRESSION undeclared Error on
MapServer 5.6.5 make.
thomas bonfort
thomas.bonfort at gmail.com
Mon Jan 17 12:29:02 EST 2011
add --with-png, and make sure the png development headers are available.
regards,
thomas
On Mon, Jan 17, 2011 at 18:07, Passmore, James H. <jpass at bgs.ac.uk> wrote:
> I'm trying to compile MapServer 5.6.5 on Ubuntu 10.10, the ultimate aim is to add a patch to support the INSPIRE language requirement (otherwise I'd use one of the existing binaries).
> I can run configure ( ./configure --with-ogr --with-gdal --with-wfsclient --with-wmsclient --with-proj --with-wcs --with-postgis --with-geos --with-sos --with-experimental-png --with-fribidi-config --with-threads --enable-debug --with-wfs ) and this completes with no errors.
> ZLIB is found:
> configure: checking where Zlib is installed...
> checking for zlibVersion in -lz... yes
> using libz from system libs (-DUSE_ZLIB).
> and I have reported:
> MapServer is now configured for
> -------------- Compiler Info -------------
> C compiler: gcc -g -fPIC -Wall
> C++ compiler: g++ -g -fPIC -Wall
> Debug: -g
> Generic NINT:
> -------------- Renderer Settings ---------
> OpenGL support:
> zlib support: -DUSE_ZLIB
> png support:
> palette rgba png support: -DUSE_RGBA_PNG
> jpeg support:
> iconv support: -DUSE_ICONV
> AGG support: -DUSE_AGG
> Cairo (SVG,PDF) support:
> Ming(flash) support:
> PDFLib support:
> -------------- Support Libraries ---------
> Proj.4 support: -DUSE_PROJ
> Libxml2 support: -DUSE_LIBXML2
> FriBidi support: -DUSE_FRIBIDI
> Curl support: -DUSE_CURL
> FastCGI support:
> Threading support: -DUSE_THREAD
> GEOS support: -DUSE_GEOS -DGEOS_HAS_SIMPLIFY
> -------------- Data Format Drivers -------
> native tiff support:
> PostGIS support: -DUSE_POSTGIS -DPOSTGIS_HAS_SERVER_VERSION
> EPPL7 support: -DUSE_EPPL
> ArcSDE support:
> OGR support: -DUSE_OGR
> GDAL support: -DUSE_GDAL
> Oracle Spatial support:
> -------------- OGC Services --------------
> WMS Server: -DUSE_WMS_SVR
> WMS Client: -DUSE_WMS_LYR
> WFS Server: -DUSE_WFS_SVR
> WFS Client: -DUSE_WMS_LYR
> WCS Server: -DUSE_WCS_SVR
> SOS Server: -DUSE_SOS_SVR
> -------------- MapScript -----------------
> PHP MapScript: no
> However when I run make I get the following error:
> local/include -I/usr/include/libxml2 -I/usr/local/include maprgbapng.c -o maprgbapng.o
> maprgbapng.c: In function ‘ms_png_write_image_init’:
> maprgbapng.c:146: error: ‘Z_BEST_COMPRESSION’ undeclared (first use in this function)
> maprgbapng.c:146: error: (Each undeclared identifier is reported only once
> maprgbapng.c:146: error: for each function it appears in.)
> make: *** [maprgbapng.o] Error 1
> Can anyone tell me where I might be going wrong?
> thanks
> James Passmore
> GIS and WWW Specialist
> Information Systems and Infrastructure
> British Geological Survey
> This message (and any attachments) is for the recipient only NERC
> is subject to the Freedom of Information Act 2000 and the contents
> of this email and any reply you make may be disclosed by NERC unless
> it is exempt from release under the Act. Any material supplied to
> NERC may be stored in an electronic records management system._______________________________________________
> mapserver-users at lists.osgeo.org
