[mapserver-users] capability to reproject to 2 different
projections within the map object of the map file
Fawcett, David (MPCA)
David.Fawcett at state.mn.us
Fri Jan 21 16:21:46 EST 2011
I believe that in CGI mode, you can only have one output projection, so your approach won't work.
You can support multiple SRS/projection in WMS mode. To do this, you put multiple SRS codes in the wms_srs metadata for a layer.
You might be able to change the map projection on the fly by changing the parameters via the URL, I assume that you would also need to change the extent values to match the projection. (I can't verify that map.projection is something that you can change via URL).
David.
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of John Mitchell
Sent: Friday, January 21, 2011 3:13 PM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] capability to reproject to 2 different projections within the map object of the map file
If I want all the layers within a map file no matter the layers own projection to have the capability to reproject to 2 different projections would I within the map object of the map file replace:
PROJECTION
"init=epsg:4326"
END
With:
PROJECTION
"init=epsg:4326"
"init=epsg:102113"
END
Thanks,
John
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110121/85df3c56/attachment.html
