[mapserver-users] java error when configuring mapserver/secureows
Chantal Rosmuller
chantal at tmcr.nl
Mon Jan 24 04:22:49 EST 2011
I still have a small problem with mapserver and secure OWS, I followed the
steps in http://www.secureows.org/trac/secureows/wiki/ServerDocumentation.
I installed mapserver and tested it.
I installed securewos server and tested it.
I edited services.xml and added:
<service serviceId="mapservertest" serviceDescription="Test"
serviceEndPoint="http://www.example.com/cgi-
bin/mapserv?map=/var/www/ms4w/apps/tutorial/htdocs/example1-1.map&layer=states&mode=map">
<roles>
<role>tomcat</role>
<role>role1</role>
</roles>
</service>
I created wmsPolicy_mapservertest.xml, with content:
<OWSPolicy service="WMS" xmlns="http://www.deegree.org/security">
<Security></Security>
<Requests>
<GetMap>
</GetMap>
<GetFeatureInfo>
</GetFeatureInfo>
<GetCapabilities>
</GetCapabilities>
<GetLegendGraphic>
</GetLegendGraphic>
</Requests>
</OWSPolicy>
The next step is Launch a command to generate the service configuration. This
is what I did:
java -cp /usr/local/owsproxyserver_20081106/apache-
tomcat-5.5.20/webapps/owsproxyserver/WEB-INF/classes/ OwsAdmin
Then I get the error:
Exception in thread "main" java.lang.NoClassDefFoundError: -cp
Caused by: java.lang.ClassNotFoundException: -cp
at java.net.URLClassLoader$1.run(URLClassLoader.java:217)
at java.security.AccessController.doPrivileged(Native Method)
at java.net.URLClassLoader.findClass(URLClassLoader.java:205)
at java.lang.ClassLoader.loadClass(ClassLoader.java:321)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:294)
at java.lang.ClassLoader.loadClass(ClassLoader.java:266)
Could not find the main class: -cp. Program will exit.
What am I doing wrong here?
Met vriendelijke groeten,
Chantal Rosmuller
TMCR Systeembeheer en advies
http://www.tmcr.nl
Let op, ik heb een nieuw telefoonnummer: 0317769041
