[mapserver-users] Raster layer problem
Carl Burn
burnsy at northcountrywoods.co.uk
Mon Jan 24 11:02:27 EST 2011
thanks for the ideas. Have tried this and here is what I got back from
gdalinfo (I couldnt seem to get ogrinfo to run on my tif files):
D:\ms4w\tools\gdal-ogr>gdalinfo
D:\opendata\minisc_gb\MiniScale\data\miniscaleno
grid.tif
Warning 1: TIFFFetchNormalTag:Incompatible type for "RichTIFFIPTC"; tag
ignored
Driver: GTiff/GeoTIFF
Files: D:\opendata\minisc_gb\MiniScale\data\miniscalenogrid.tif
Size is 7000, 13000
Coordinate System is `'
Origin = (0.000000000000000,1300000.000000000000000)
Pixel Size = (100.000000000000000,-100.000000000000000)
Metadata:
TIFFTAG_SOFTWARE=Adobe Photoshop CS4 Macintosh
TIFFTAG_DATETIME=2009:12:04 12:52:34
TIFFTAG_XRESOLUTION=254
TIFFTAG_YRESOLUTION=254
TIFFTAG_RESOLUTIONUNIT=2 (pixels/inch)
Image Structure Metadata:
COMPRESSION=LZW
INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left ( 0.000, 1300000.000)
Lower Left ( 0.0000000, 0.0000000)
Upper Right ( 700000.000, 1300000.000)
Lower Right ( 700000.000, 0.000)
Center ( 350000.000, 650000.000)
Band 1 Block=7000x12 Type=Byte, ColorInterp=Red
Band 2 Block=7000x12 Type=Byte, ColorInterp=Green
Band 3 Block=7000x12 Type=Byte, ColorInterp=Blue
I took all of the stuff out of the map file with the exception of the extent
and ran shp2img and it runs without any problem, generating a blank png
image. I guess I need to add the correct extent information to get the image
to display?
Cheers
Carl
On Mon, Jan 24, 2011 at 2:29 PM, Jeff McKenna <jmckenna at gatewaygeomatics.com
> wrote:
> Hello,
> Here are my quick thoughts:
> - remove all projection objects from your mapfile
> - remove all layers from your mapfile except the one raster/tif layer
> - use the ogrinfo utility, which is included in MS4W, to get the extents of
> your tif file (http://www.gdal.org/ogrinfo.html)
> - use those extents in your mapfile's EXTENT parameter
> - test your mapfile with the shp2img utility, which is also included in
> MS4W (http://www.mapserver.org/utilities/shp2img.html)
> - note that MS4W is already configured for the following IMAGEPATH and
> IMAGEURL parameters:
> IMAGEPATH "/ms4w/tmp/ms_tmp/"
> IMAGEURL "/ms_tmp/"
> (the above imagepath value assumes that you have MS4W installed at a root
> of a drive...if you used the setup.exe installer you might have installed it
> elsewhere, so that imagepath value might be different)
> Hope those quick thoughts help.
> -jeff
> Jeff McKenna
> MapServer Consulting and Training Services
> http://www.gatewaygeomatics.com/
> On 11-01-24 5:57 AM, Carl Burn wrote:
>> Hello All,
>> I am a newcomer to this list so forgive me if I make any blunders.
>> I am trying to render a map image from mapserver using a tif file which
>> has a georeferencing .tab file in the same folder and I am getting
>> nowhere with it. The tab file content is as follows:
>> ======= TAB File ==================
>> !table
>> !version 300
>> !charset WindowsLatin1
>> Definition Table
>> File "MiniScalenogrid.tif"
>> Type "RASTER"
>> (0,0) (0,13000) Label "Pt 1",
>> (700000,0) (7000,13000) Label "Pt 2",
>> (700000,1300000) (7000,0) Label "Pt 3",
>> (0,1300000) (0,0) Label "Pt 4"
>> CoordSys Earth Projection 8, 79, "m", -2, 49, 0.9996012717, 400000,
>> -100000
>> Units "m"
>> RasterStyle 7 0
>> ========Tab File ends =======================
>> The mapfile is below:
>> ========== Map file =========================
>> MAP
>> NAME "osminiscale"
>> # Map image size
>> SIZE 800 800
>> UNITS meters
>> EXTENT 41069.1 -1149.02 665378.01 1231178.57
>> FONTSET './etc/fonts.txt'
>> SYMBOLSET './etc/symbols.sym'
>> PROJECTION
>> 'init=epsg:27700'
>> END
>> # Background color for the map canvas -- change as desired
>> IMAGECOLOR 255 255 255
>> IMAGEQUALITY 95
>> IMAGETYPE png
>> OUTPUTFORMAT
>> NAME png
>> DRIVER 'GD/PNG'
>> MIMETYPE 'image/png'
>> IMAGEMODE RGBA
>> EXTENSION 'png'
>> END
>> # Legend
>> LEGEND
>> STATUS OFF
>> KEYSIZE 18 12
>> LABEL
>> TYPE BITMAP
>> SIZE MEDIUM
>> COLOR 0 0 89
>> END
>> END
>> # Web interface definition. Only the template parameter
>> # is required to display a map. See MapServer documentation
>> WEB
>> # Set IMAGEPATH to the path where MapServer should
>> # write its output.
>> IMAGEPATH '/tmp/'
>> # Set IMAGEURL to the url that points to IMAGEPATH
>> # as defined in your web server configuration
>> IMAGEURL '/tmp/'
>> # WMS server settings
>> METADATA
>> 'ows_title' 'miniscale'
>> 'ows_onlineresource'
>> http://www.foobar.com/cgi-bin/mapserv.exe?map=D:/ms4w/Apache/cgi-bin/osminiscale.map
>> 'ows_srs' 'EPSG:27700'
>> END
>> #Scale range at which web interface will operate
>> # Template and header/footer settings
>> # Only the template parameter is required to display a map. See
>> TEMPLATE 'fooOnlyForWMSGetFeatureInfo'
>> END
>> LAYER
>> NAME 'MiniScalenogrid'
>> TYPE RASTER
>> DUMP true
>> TEMPLATE fooOnlyForWMSGetFeatureInfo
>> DATA 'D:/opendata/minisc_gb/MiniScale/data/MiniScalenogrid.tif'
>> METADATA
>> 'ows_title' 'MiniScalenogrid'
>> END
>> STATUS OFF
>> TRANSPARENCY 100
>> PROJECTION
>> 'init=epsg:27700'
>> END
>> END
>> LAYER
>> NAME 'MiniScalewithgrid'
>> TYPE RASTER
>> DUMP true
>> DATA 'D:/opendata/minisc_gb/MiniScale/data/MiniScalewithgrid.tif'
>> METADATA
>> 'ows_title' 'MiniScalewithgrid'
>> END
>> STATUS OFF
>> TRANSPARENCY 100
>> PROJECTION
>> 'init=epsg:27700'
>> END
>> END
>> END
>> ============ Map File ends ==========================
>> I am not getting an image from the map server and have run shp2img with
>> the following results:
>> msProcessProjection(): Projection library error. unknown elliptical
>> parameter name
>> Any clues or pointers would be great.
>> Thanks
>> Burnsy
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110124/5d0d458d/attachment.html
