[mapserver-users] changing dynamically LABEL BACKGROUNDCOLOR
thomas bonfort
thomas.bonfort at gmail.com
Fri Jan 28 02:23:31 EST 2011
Before starting to implement something extensive around label
BACKGROUNDCOLOR, you should be aware that this keyword will not be
supported anymore starting from version 6.0.
it is replaced with a
STYLE
GEOMTRANSFORM LABELPOLY
COLOR r g b
END
which greatly extends the possibilities of styling the label
background (e.g. outlinecolor, symbol, offset, opacity, etc...), as
all the keywords relating to STYLE are applicable.
regards,
thomas
On Thu, Jan 27, 2011 at 22:55, Jean-François Gigand
<jean-francois at gigand.fr> wrote:
> Use one CLASS for each colour used, set them to depend on your
> attribute and repeat the LABEL definition for each of them.
> If you the number of colours is limited, this would probably be a solution.
> Jeff
> 2011/1/27 tommaso <tommasodb at googlemail.com>:
>> On Thu, 2011-01-27 at 16:47 +0100, Julien Cigar wrote:
>> use SLD ?
>> Thanks, this were a solution but I should radically change my project. I
>> will try it if there is not other ways.
>> Other ideas?
>> Tommaso
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
