[mapserver-users] Re: Installing PHP MapScript with MapServer
6.0.0-3 and PHP 5.3.6 on Mac OS X 10.6.8
Carlos Ruiz
boolean10001 at yahoo.com
Wed Jul 6 13:37:27 EDT 2011
Léo,
If you server is not a production server, please make sure that you have the php.ini error handling as follows:
error_reporting = E_ALL
Remember to restart Apache.
Also, in the MAP section, add something like this:
DEBUG ON
CONFIG "MS_ERRORFILE" "/var/www/html/errores.txt"
Let's see what happens.
Cheers from México
IC Carlos Ruiz
To: mapserver-users at lists.osgeo.org
Sent: Tuesday, July 5, 2011 11:19 AM
Subject: [mapserver-users] Re: Installing PHP MapScript with MapServer 6.0.0-3 and PHP 5.3.6 on Mac OS X 10.6.8
Thanks to both of you for your answers.
I've allready edit my php.ini to add "extension=php_mapscript.so" and with a
phpinfo() I can see the section about MapScript.
Moreover when I run this script to test if the extension is loaded or not
and I have a positive result, so I think that PHP MapScript is working:
if (!extension_loaded('MapScript')) {
echo"Not loaded";
else {
echo"Loaded!";
But when I try to run the example script from the mapserver.org
documentation (without the dl() instruction), it doesn't work and I have no
error message, just an empty page. Here is my php code:
<?php
$map = ms_newMapObj("~/macbook/Sites/mapeserver/introduction/test.map");
$image = $map->draw();
$image_url = $image->saveWebImage();
echo'<html>
<head>
<title>Exemple : Afficher un shapefile</title>
</head>
<body>
'.$image_url.'
</body>
</html>';
And here is my mapfile:
MAP
NAME "Europe en bleu"
SIZE 400 400
STATUS ON
EXTENT -31.2467 27.6065 40.1199 80.762
UNITS DD
SHAPEPATH "~/macbook/Sites/mapserver/introduction/shape/"
WEB
IMAGEPATH '~/macbook/Sites/mapeserver/temp/'
IMAGEURL '/temp/'
END
LAYER
NAME "Europe"
TYPE POLYGON
STATUS ON
DATA "europe"
CLASS
STYLE
COLOR 20 10 110
OUTLINECOLOR 200 200 200
END
END
END
END
Maybe I've made a mistake in one of these files…
Thanks for your help !
Léo
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Installing-PHP-MapScript-with-MapServer-6-0-0-3-and-PHP-5-3-6-on-Mac-OS-X-10-6-8-tp6546297p6550486.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110706/48c1bf91/attachment-0001.html
