[mapserver-users] MapServer CGI problem with tomcat 6/7
Hunter, David
David.Hunter at lpsvcs.com
Fri Jul 15 12:39:22 EDT 2011
I have a custom web application that uses MapServer CGI to display maps. It currently runs under Tomcat 5 ok. However, when trying to migrate to Tomcat 6 or 7, I run into a problem that seems to be specific to mapserv.exe.
When I make a call to CATALINA_HOME/cgi-bin/mapserv.exe, the browser displays a blank page and the log shows the response as "200 -" (response="OK, zero byte length"). When I call other executables, they respond as expected (such as CATALINA_HOME/cgi-bin/gifsample.exe), it is just mapserv.exe that returns zero bytes, so the CGI configuration in Tomcat seems to be OK.
I tried mapserv.exe at the command line, and it responds as expected, so it seems to be installed correctly
At this point, I'm assuming that there is some kind of configuration setting (valve?) in Tomcat 6.0 and 7.0 that needs to set or tweaked, but I've run into a wall trying to figure out what the might be. Anybody out there with any ideas?
David S. Hunter
Lead Software Engineer
LPS Insurance Risk Management Services
Lender Processing Services, Inc.
5353 Gamble Drive, Suite 201
Saint Louis Park, MN 55416
Office: 952.542.1440 ext. 256
Fax: 952.542.3859
david.hunter at lpsvcs.com<mailto:david.hunter at lpsvcs.com>
www.lpsvcs.com<http://www.lpsvcs.com>
The information contained in this message is proprietary and/or confidential. If you are not the intended recipient, please: (i) delete the message and all copies; (ii) do not disclose, distribute or use the message in any manner; and (iii) notify the sender immediately. In addition, please be aware that any message addressed to our domain is subject to archiving and review by persons other than the intended recipient. Thank you.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110715/9a16fe72/attachment-0001.html
