[mapserver-users] defresolution and resolution issues in
Mapserver 6
Smith, Michael ERDC-CRREL-NH
Michael.Smith at usace.army.mil
Mon Jul 18 12:49:22 EDT 2011
No, they are not annotation layers.
I'll pull the latest svn and rebuild and if I still have issues, I'll
create a small test case.
Mike
Michael Smith
Remote Sensing/GIS Center
US Army Corps of Engineers
On 7/18/11 12:44 PM, "thomas bonfort" <thomas.bonfort at gmail.com> wrote:
>Mike,
>I am not able to reproduce with the msautotest tests:
>These are the steps I have taken, in msautotest/renderers
>- mapserv -nh
>QUERY_STRING='map=point_ellipse.map&mode=map&map_resolution=144&map_size=8
>00+600'
>> result/point_ellipse.png.png
>- convert -scale 50% result/point_ellipse.png.png
>- compare visually expected/point_ellipse.png.png
>result/point_ellipse.png.png which should be nearly identical
>ps: I've added the labels-anno.map test in case the problem you werre
>having only affects annotation layers, but that does not seem to be
>the case.
>thomas
>On Mon, Jul 18, 2011 at 16:49, Smith, Michael ERDC-CRREL-NH
><Michael.Smith at usace.army.mil> wrote:
>> All,
>> I'm seeing symbol scaling and label size/placement issues (see images
>>and
>> pdfs for differences) when trying to scale up for higher resolution
>>output.
>> Font size is scaling properly but the symbols are larger at higher dpi
>>than
>> it should be and labels are not being displayed (perhaps due to label
>>buffer
>> issues) at the higher dpi.
>> Are there additional settings I should be making beyond setting
>>resolution
>> and defresolution?
>> Example URLs
>>http://localgost/cgi-bin/mapserv6?TRANSPARENT=true&map_resolution=72&MAP_
>>IMAGETYPE=png&MAPEXT=-8043793.5+5411335.5+-8041721.0+5413610.5&map_defres
>>olution=72&MAP_SIZE=440+483&LAYERS=watersmap&MODE=map&MAP=cm2_test.map
>>http://localhost/cgi-bin/mapserv6?TRANSPARENT=true&map_resolution=144&MAP
>>_IMAGETYPE=png&MAPEXT=-8043793.5+5411335.5+-8041721.0+5413610.5&map_defre
>>solution=72&MAP_SIZE=880+966&LAYERS=watersmap&MODE=map&MAP=cm2_test.map
>> Mike
>> Michael Smith
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
