[mapserver-users] mapserver publish road
thomas bonfort
thomas.bonfort at gmail.com
Tue Jul 19 08:31:21 EDT 2011
2011/7/19 Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi>:
> Hi,
> I believe that most cartographers would say that the uDig way to to draw the outlines is ugly and the Mapserver way looks better but it is partly a matter of taste. However, at least for me the continuous black lines also give a feeling that it is not possible or allowed to drive from one street to another.
> I would try to draw the streets as two separate layers with own styels instead of a single layer with two styles, perhaps that would lead to continuos black outlines.
Doing so this way would also result in the black lines disappearing.
thomas
> -Jukka Rahkonen-
> 赫玄惠 [xiaoshitou1986126 at 126.com] wrote:
>> I encounter a question. use one same shape file, when I use it in mapserver it like
> [cid:752891ff$1$13140d5bf06$Coremail$xiaoshitou1986126 at 126.com]
> but in udig it like
> [cid:3a893870$2$13140d5bf06$Coremail$xiaoshitou1986126 at 126.com]
> when two street intersect together, udig can paint map with the black border,but mapserver can't. Anyone know why?
> my mapfile is this:
> MAP
> SIZE 800 450
> EXTENT -200 0 200 100
> IMAGECOLOR 180 180 250
> UNITS DD
> debug 5
> CONFIG "MS_ERRORFILE" "\ms4w\tmp\ms_error.txt"
> FONTSET "D:\ms4w\apps\fonts\fonts.list"
> PROJECTION
> "init=epsg:4326"
> END
> OUTPUTFORMAT
> NAME png24#AGG
> DRIVER "GD/PNG" #AGG/PNG IMAGEMODE RGB
> MIMETYPE IMAGE/PNG
> EXTENSION PNG
> #FORMATOPTION TRANSPARENT=ON
> #FORMATOPTION INTERLANCE=OFF
> END
> IMAGETYPE png24 #AGG
> WEB
> IMAGEPATH "\ms4w\Apache\htdocs\tmp\"
> IMAGEURL "\tmp\"
> END
> SYMBOL
> NAME 'cartoline'
> TYPE CARTOLINE
> LINECAP butt
> LINEJOIN bevel
> LINEJOINMAXSIZE 3
> END
> LAYER
> NAME 01
> TYPE LINE
> debug 5
> STATUS on
> TRANSPARENCY alpha
> CONNECTIONTYPE postgis
> CONNECTION "user=* dbname=* host=* port=* password=* "
> DATA "the_geom from *** using unique gid"
> processing "slose_connection=defer"
> DUMP TRUE
> CLASS
> STYLE
> COLOR 0 0 0
> SYMBOL 'cartoline'
> ANTIALIAS TRUE
> SIZE 10
> END
> STYLE
> COLOR 255 255 0
> SYMBOL 'cartoline'
> ANTIALIAS TRUE
> &nbs p; SIZE 8
> END
> END
> END
> END
> mapserver-users at lists.osgeo.org
