[mapserver-users] Expression and nquery with sde issue
Steve Lime
sdlime at gmail.com
Wed Jul 20 11:18:52 EDT 2011
I don't have access to SDE on my home box but will in a few days when I'm
back to work... SDE uses the function msDoubleToString in mapstring.c to
convert values (MapServer holds all attribute values as strings). The
conversion uses the %g conversion specifier. That must be the problem.
If you're building from source you could try changing the calls to
msDoubleToString in mapsde.c to pass MS_TRUE instead of MS_FALSE for the
last argument. That will trigger the use of %f, perhaps that will make a
difference.
Could also try changing the conversion specifiers in msDoubleToString to use
%Lf and %Lg and see that fixes things.
Steve
On Tue, Jul 19, 2011 at 12:41 PM, Mario Franco <mario.franco at ydreams.com>wrote:
> Can anyone that uses mapserver with sde reproduce the label and expression
> issue that I'm having?
> On 15-07-2011 15:38, Mario Franco wrote:
> The version is Mapserver 5.6.3 and using the attribute as label was how
> find out the values were being rounded.
> For example the attribute has values from 1000 to 170000 and if the value
> is smaller than 100000 rounds the value with one decimal but above 100000
> rounds to and integer.
> I'm using sqlserver with the SDE and the atrribute type is numeric could
> this have anything to do with it?
> Mário
> On 15-07-2011 15:23, Steve Lime wrote:
> On issue one, what version are you using? MapServer shouldn't be rounding
> the value. The comparison should be being done as a double. It might be
> helpful to see a sample dataset although if this is SDE I can't test on my
> end. One thing to try to help diagnose the problem would be to create a
> sample mapfile that draws your layer and uses the area attribute for
> labeling. What shows up for labels?
> Steve
> Sent from my iPad
> On Jul 15, 2011, at 5:14 AM, Mario Franco <mario.franco at ydreams.com>
> wrote:
> Hi,
> I having two issues with mapserver if anyone can help me I would be
> appreciated.
> The first has to do with an Expression in a class:
> I have a shape with an attribute with the 172060.0937 but when add to the
> class:
> EXPRESSION ( [AREA] = 172060.0937 )
> The problem is that this expression returns false because mapserver is
> rounding the double value from the database. If I compare with:
> EXPRESSION ( [AREA] = 172060)
> it works. There is any way to turn this off or to increase the precision?
> The second issue is:
> I'm using this url (
> http://localhost:82/cgi-bin/mapserv.exe?map=D%3a\projects\Inag\InterSIG+II\InterSIG+Website\Trunk\InterSIG+ASP.NET\Maps%2fintersig_281.map&qlayer=Concelhos&layers=Concelhos&MAPSIZE=629%20467&MINX=-232614.525612302&MINY=-49761.6088409424&MAXX=676601.080299802&MAXY=625284&mode=NQUERY&MAPSHAPE=POLYGON%28%28-232614%20-49761,%20-232614%20625284,%20676601%20625284,%20676601%20-49761,%20-232614%20-49761%29%29<http://localhost:82/cgi-bin/mapserv.exe?map=D%3a%5Cprojects%5CInag%5CInterSIG+II%5CInterSIG+Website%5CTrunk%5CInterSIG+ASP.NET%5CMaps%2fintersig_281.map&qlayer=Concelhos&layers=Concelhos&MAPSIZE=629%20467&MINX=-232614.525612302&MINY=-49761.6088409424&MAXX=676601.080299802&MAXY=625284&mode=NQUERY&MAPSHAPE=POLYGON%28%28-232614%20-49761,%20-232614%20625284,%20676601%20625284,%20676601%20-49761,%20-232614%20-49761%29%29>)
> to execute a nquery but I always get the error "msSDELayerGetShape(): SDE
> error. SE_stream_fetch_row(): Invalid parameter value passed to function.
> (-66) "
> The log doesn't help that much:
> [Fri Jul 15 10:47:19 2011].20000 msSDELayerOpen(): Layer Concelhos opened
> from scratch.
> [Fri Jul 15 10:47:23 2011].35000
> msConnPoolRegister(Concelhos,ydinag2,port:5151,sde,sde,sde,01D6BCC0)
> [Fri Jul 15 10:47:23 2011].35000 msSDELayerOpen(): Layer Concelhos
> specified version SDE.DEFAULT.
> [Fri Jul 15 10:47:23 2011].42000 msSDEGetLayerInfo(): Looking for layer by
> SDE.CONCELH_PTCONT_2008_0_596, SHAPE, ydinag2,port:5151,sde,sde,sde
> [Fri Jul 15 10:47:23 2011].42000 msSDEGetLayerInfo(): No cached layerid
> found.
> [Fri Jul 15 10:47:23 2011].63000 msSDELCacheAdd(): Caching id for
> [Fri Jul 15 10:47:23 2011].72000 Getting all column information in
> msSDELayerInitItemInfo
> [Fri Jul 15 10:47:23 2011].79000 msSDELayerInitItemInfo(): getting info for
> DICO
> CONCELHO
> DI
> DISTRITO
> CCDR
> NUT3
> NUT3_NOME
> NUT2
> NUT2_NOME
> AREA2008_1
> objectid
> SHAPE
> [Fri Jul 15 10:47:23 2011].79000 Column information has already been
> gotten... returning from msSDELayerInitItemInfo
> [Fri Jul 15 10:47:43 2011].122000 msSDELayerGetShape(): SDE error.
> SE_stream_fetch_row(): Invalid parameter value passed to function. (-66)
> [Fri Jul 15 10:47:43 2011].126000 msFreeMap(): freeing map at 01D3EFE8.
> [Fri Jul 15 10:47:43 2011].126000 msSDELayerCloseConnection(): Closing
> connection for layer Concelhos.
> msConnPoolRelease(Concelhos,ydinag2,port:5151,sde,sde,sde,01D6BCC0)
> msConnPoolClose(ydinag2,port:5151,sde,sde,sde,01D6BCC0)
> [Fri Jul 15 10:47:43 2011].156000 msSDELayerClose(): Closing layer
> Concelhos.
> msConnPoolRelease(Concelhos,ydinag2,port:5151,sde,sde,sde,00000000)
> [Fri Jul 15 10:47:43 2011].156000 msConnPoolRelease(): Unable to find
> handle for layer 'Concelhos'.
> [Fri Jul 15 10:47:43 2011].156000 msConnPoolRelease(): General error
> message. Unable to find handle for layer 'Concelhos'.
> Here part of my configuration:
> LAYER
> NAME "Concelhos"
> METADATA
> "wms_title" "Concelhos" # required
> "wfs_title" "Concelhos" # required
> "gml_featureid" "ID" ## REQUIRED
> "gml_geometries" "geom"
> "gml_geom_type" "polygon"
> "gml_include_items" "all" # Optional (serves all attributes for layer)
> "gml_exclude_items" "GEOMETRY,OBJECTID"
> "ows_include_items" "all"
> "ows_exclude_items" "GEOMETRY,OBJECTID"
> END
> DUMP true
> TOLERANCE 10
> TOLERANCEUNITS meters
> TYPE polygon
> #CONNECTIONTYPE SDE
> CONNECTIONTYPE PLUGIN
> PLUGIN "D:/ms4w/Apache/specialplugins/msplugin_sde_92.dll"
> CONNECTION "ydinag2,port:5151,sde,sde,sde"
> DATA "SDE.CONCELH_PTCONT_2008_0_596,SHAPE,SDE.DEFAULT"
> PROJECTION
> "init=EPSG:3763" #--sistema de coordenadas desta layer na origem
> END
> STATUS ON
> OPACITY 100
> TEMPLATE '../Templates/Identify/t.html'
> I'm using Mapserver 5.6.3, I know it's not the latest but I didn't updated
> yet.
> Any help would be useful and thx in advance.
> Mário Franco
> mapserver-users at lists.osgeo.org
> Mário Franco | Software Developer | mario.franco at ydreams.com
> YDreams - Informática S.A. | www.ydreams.com | +351 210 314 000 | Blog<http://www.ydreams.com/blog/>|
> YouTube <http://www.youtube.com/ydreams> | Vimeo<http://www.vimeo.com/ydreams/>|
> Twitter <http://twitter.com/ydreams/>
> *Disclaimer and Confidentiality Notice:* YDreams accepts no responsibility
> or liability whatsoever with regard to the information herein contained.
> This message including any attachment hereof is confidential and may be
> privileged or otherwise legally protected from disclosure and may only be
> read, copied and used by the intended recipient. If you are not the intended
> recipient, please contact the sender immediately (+351 210 314 000) and
> delete this email and any attachment permanently from your system. You must
> not copy this email or any attachment or disclose its/their contents to any
> other person or entity. Thank you.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110720/c2c3d69e/attachment-0001.html
