[mapserver-users] Re: ArcSDE 9.3.1 QUERYMAP,
QUERY or GETFEATUREINFO not workin (Mapserver 6)
Michelle Douvil
mrdouville at shaw.ca
Thu Jul 21 14:35:42 EDT 2011
Hi All,
Using GDB a bit more to look at MS4W calls and I see that the SDE C API dlls
are called after the response?
I am not sure if that has anything to do with it..
http://osgeo-org.1803224.n2.nabble.com/file/n6608018/ms4w_fails.txt
ms4w_fails.txt
http://osgeo-org.1803224.n2.nabble.com/file/n6608018/map5_works.txt
map5_works.txt
http://osgeo-org.1803224.n2.nabble.com/file/n6608018/map6_fails.txt
map6_fails.txt
??breakpoints-invalid
Content-type: text/plain
GetFeatureInfo results:
Search returned no results.
Reading symbols from
E:\sw_nt\ms4w\Apache\specialplugins\msplugin_sde_93.dll...(no debugging
symbols found)...done.
Loaded symbols for E:\sw_nt\ms4w\Apache\specialplugins\msplugin_sde_93.dll
Reading symbols from E:\sw_nt\mapserver6\sde.dll...(no debugging symbols
found)...done.
Loaded symbols for E:\sw_nt\mapserver6\sde.dll
Reading symbols from E:\sw_nt\mapserver6\sg.dll...(no debugging symbols
found)...done.
Loaded symbols for E:\sw_nt\mapserver6\sg.dll
Reading symbols from E:\sw_nt\mapserver6\pe.dll...(no debugging symbols
found)...done.
Loaded symbols for E:\sw_nt\mapserver6\pe.dll
??breakpoints-invalid.............................
View this message in context: http://osgeo-org.1803224.n2.nabble.com/ArcSDE-9-3-1-QUERYMAP-QUERY-or-GETFEATUREINFO-not-workin-Mapserver-6-tp6600091p6608018.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
