[mapserver-users] Problem GetFeature with geom filter on WFS
Stéphane Brunner
stephane.brunner at camptocamp.com
Thu Jul 28 10:18:49 EDT 2011
Hello,
I log the sql request on spatial filter and I have this:
select "oid","nummer","gemeinde","gueltigkeit","flgrundb","quote","eigentuemer","adresse_lang",encode(ST_AsBinary(ST_Force_2D("geom"),'NDR'),'hex')
as geom,"oid" from (SELECT oid, t1.geom, t1.nummer, t2.gemeinde,
t1.gueltigkeit1_txt as gueltigkeit, t2.flgrundb, ((t2.zaehler::text ||
'/'::text) || t2.nenner::text) AS quote, t2.eigentuemer,
(((t2.adresse::text || ', '::text) || t2.plz::text) || ' '::text) ||
t2.ort::text AS adresse_lang FROM av.liegenschaften_liegenschaft_area
as t1, av.view_gemlis_geomaste_parzelle as t2 WHERE t1.gdid = t2.gdeid
and t1.nummer = t2.parznr::text) AS foo where geom &&
GeomFromText('POLYGON((620000 218000,620000 278000,690000
278000,690000 218000,620000 218000))',-1) limit 100
I didn't see any postggis filter than I try to do a spatial filter on
one of the 100 first results
Than I have a correct result ...
Than why mapserver doesn't use postgis spatial filter ? Does I miss something ?
Thank-you in advance
Stéphane Brunner
2011/7/26 Stéphane Brunner <stephane.brunner at camptocamp.com>:
> Hello,
> I just test it with a shape file, and it's working...
> I will investigate a little bit more to know why it's not working with postgres.
> Sincerely
> Stéphane Brunner
> 2011/7/25 Steve Lime <sdlime at gmail.com>:
>> Never mind on version, I saw 6.0.0 in the response... ;-) Steve
>> On Mon, Jul 25, 2011 at 6:19 AM, Stéphane Brunner
>> <stephane.brunner at camptocamp.com> wrote:
>>> Hello,
>>> I have the mapfile [0]. when I done a GetFeature on the nummer [1] I
>>> have 4 results [2] (with duplicate but it's an other issue).
>>> When I done a spatial filter [3] I have no results [4] but I should
>>> have at least one result ...
>>> Thanks in advance for having a look on this issue.
>>> Sincerely yours
>>> Stéphane Brunner
>>> Following: specified, GetCapabilities [5], describefeaturetype [6].
>>> mapfile [0]:
>>> MAP
>>> NAME "map"
>>> EXTENT 620000 218000 690000 278000
>>> UNITS METERS
>>> IMAGETYPE jpeg
>>> RESOLUTION 72
>>> DEFRESOLUTION 72
>>> IMAGECOLOR 255 255 255
>>> STATUS ON
>>> FONTSET "fonts.conf"
>>> SYMBOLSET "symbole.sym"
>>> MAXSIZE 5000
>>> PROJECTION
>>> "init=epsg:21781"
>>> END
>>> # Used by overlays
>>> OUTPUTFORMAT
>>> NAME png256
>>> DRIVER AGG/PNG
>>> MIMETYPE "image/png256"
>>> IMAGEMODE RGBA
>>> EXTENSION "png"
>>> FORMATOPTION "INTERLACE=OFF"
>>> FORMATOPTION "QUANTIZE_FORCE=ON"
>>> FORMATOPTION "QUANTIZE_DITHER=OFF"
>>> FORMATOPTION "QUANTIZE_COLORS=256"
>>> END
>>> OUTPUTFORMAT
>>> NAME png
>>> DRIVER AGG/PNG
>>> MIMETYPE "image/png"
>>> IMAGEMODE RGBA
>>> EXTENSION "png"
>>> END
>>> WEB
>>> METADATA
>>> "ows_title" "map"
>>> "ows_srs" "epsg:21781"
>>> "ows_encoding" "UTF-8"
>>> "wms_feature_info_mime_type" "application/vnd.ogc.gml"
>>> "wms_enable_request" "*"
>>> "ows_enable_request" "*"
>>> "gml_include_items" "all"
>>> "gml_featureid" "id"
>>> "wfs_title" "map"
>>> "wfs_srs" "epsg:21781"
>>> END
>>> IMAGEPATH '/var/tmp/'
>>> END
>>> LEGEND
>>> IMAGECOLOR 240 240 240
>>> LABEL
>>> FONT arial
>>> ANTIALIAS true
>>> TYPE truetype
>>> SIZE 9
>>> COLOR 0 0 0
>>> END
>>> END
>>> LAYER
>>> NAME "Liegenschaft_Query"
>>> TYPE POLYGON
>>> STATUS ON
>>> TEMPLATE fooOnlyForWMSGetFeatureInfo
>>> CONNECTIONTYPE postgis
>>> PROCESSING "CLOSE_CONNECTION=DEFER"
>>> CONNECTION "user=www-data password=www-data dbname=dev host=localhost"
>>> DATA "geom from (SELECT oid, t1.geom, t1.nummer FROM
>>> av.view_i_liegenschaft_all AS t1) AS foo using unique oid using
>>> SRID=-1"
>>> # GROUP "TOPIC_Liegenschaften_LN"
>>> METADATA
>>> "ows_title" "Liegenschaft_Query"
>>> "id_attribute_string" "oid"
>>> "ows_featureid" "oid"
>>> "ows_geometries" "geom"
>>> "ows_geom_type" "polygon"
>>> "query_returned_attributes" "nummer"
>>> "gml_include_items" "oid,nummer,geom"
>>> "gml_geometries" "geom"
>>> "gml_geom_type" "polygon"
>>> "gml_nummer_type" "Character"
>>> #"gml_groups" "TOPIC_Liegenschaften_LN"
>>> "gml_featureid" "oid"
>>> "wfs_title" "Liegenschaft_Query"
>>> END
>>> DUMP TRUE
>>> PROJECTION
>>> "init=epsg:21781"
>>> END
>>> CLASS
>>> NAME "Liegenschaft"
>>> STYLE
>>> SYMBOL "circle"
>>> SIZE 3
>>> OUTLINECOLOR 0 0 0
>>> END
>>> END
>>> END
>>> END
>>> query on the nummer [1]:
>>> <wfs:GetFeature xmlns:wfs="http://www.opengis.net/wfs" service="WFS"
>>> version="1.0.0" maxFeatures="100"
>>> xsi:schemaLocation="http://www.opengis.net/wfs
>>> http://schemas.opengis.net/wfs/1.0.0/WFS-transaction.xsd"
>>> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
>>> <wfs:Query typeName="feature:Liegenschaft_Query"
>>> xmlns:feature="http://mapserver.gis.umn.edu/mapserver">
>>> <ogc:Filter xmlns:ogc="http://www.opengis.net/ogc">
>>> <ogc:PropertyIsEqualTo>
>>> <ogc:PropertyName>nummer</ogc:PropertyName>
>>> <ogc:Literal>3634</ogc:Literal>
>>> </ogc:PropertyIsEqualTo>
>>> </ogc:Filter>
>>> </wfs:Query>
>>> </wfs:GetFeature>
>>> response on the nummer [2]:
>>> <?xml version='1.0' encoding="UTF-8" ?>
>>> <wfs:FeatureCollection
>>> xmlns:ms="http://mapserver.gis.umn.edu/mapserver"
>>> xmlns:gml="http://www.opengis.net/gml"
>>> http://schemas.opengis.net/wfs/1.0.0/WFS-basic.xsd
>>> http://c2cpc89.camptocamp.com/sbrunner/mapserv?SERVICE=WFS&VERSION=1.0.0&REQUEST=DescribeFeatureType&TYPENAME=feature:Liegenschaft_Query&OUTPUTFORMAT=XMLSCHEMA">
>>> <gml:boundedBy>
>>> <gml:Box srsName="EPSG:21781">
>>> <gml:coordinates>661054.808000,244611.321000
>>> 663053.704000,244888.622000</gml:coordinates>
>>> </gml:Box>
>>> </gml:boundedBy>
>>> <gml:featureMember>
>>> <ms:Liegenschaft_Query fid="Liegenschaft_Query.2380997">
>>> <gml:boundedBy>
>>> <gml:coordinates>661054.808000,244854.251000
>>> 661088.687000,244888.622000</gml:coordinates>
>>> </gml:Box>
>>> </gml:boundedBy>
>>> <ms:geom>
>>> <gml:Polygon srsName="EPSG:21781">
>>> <gml:outerBoundaryIs>
>>> <gml:LinearRing>
>>> <gml:coordinates>661076.579000,244888.622000
>>> 661054.808000,244875.484000 661062.744000,244858.448000
>>> 661064.653000,244854.251000 661088.687000,244869.173000
>>> 661076.579000,244888.622000 </gml:coordinates>
>>> </gml:LinearRing>
>>> </gml:outerBoundaryIs>
>>> </gml:Polygon>
>>> </ms:geom>
>>> <ms:oid>2380997</ms:oid>
>>> <ms:nummer>3634</ms:nummer>
>>> </ms:Liegenschaft_Query>
>>> </gml:featureMember>
>>> <gml:featureMember>
>>> <gml:boundedBy>
>>> </gml:Box>
>>> </gml:boundedBy>
>>> <ms:geom>
>>> <gml:LinearRing>
>>> </gml:LinearRing>
>>> </gml:Polygon>
>>> </ms:geom>
>>> <gml:featureMember>
>>> <ms:Liegenschaft_Query fid="Liegenschaft_Query.2384539">
>>> <gml:boundedBy>
>>> <gml:coordinates>663017.565000,244611.321000
>>> 663053.704000,244650.084000</gml:coordinates>
>>> </gml:Box>
>>> </gml:boundedBy>
>>> <ms:geom>
>>> <gml:LinearRing>
>>> <gml:coordinates>663017.565000,244635.722000
>>> 663033.235000,244611.321000 663045.949000,244619.485000
>>> 663053.704000,244626.417000 663034.337000,244650.084000
>>> 663017.565000,244635.722000 </gml:coordinates>
>>> </gml:LinearRing>
>>> </gml:Polygon>
>>> </ms:geom>
>>> <ms:oid>2384539</ms:oid>
>>> <gml:featureMember>
>>> <gml:boundedBy>
>>> </gml:Box>
>>> </gml:boundedBy>
>>> <ms:geom>
>>> <gml:LinearRing>
>>> </gml:LinearRing>
>>> </gml:Polygon>
>>> </ms:geom>
>>> </wfs:FeatureCollection>
>>> query with spatial filter [3]:
>>> <ogc:Intersects>
>>> <ogc:PropertyName>geom</ogc:PropertyName>
>>> <gml:Point xmlns:gml="http://www.opengis.net/gml" srsName="EPSG:21781">
>>> <gml:coordinates decimal="." cs="," ts="
>>> ">661070.024,244872.084</gml:coordinates>
>>> </gml:Point>
>>> </ogc:Intersects>
>>> </ogc:Filter>
>>> </wfs:Query>
>>> </wfs:GetFeature>
>>> response with spatial filter [4]:
>>> <gml:boundedBy>
>>> <gml:null>missing</gml:null>
>>> </gml:boundedBy>
>>> GetCapabilities [5]:
>>> <WFS_Capabilities
>>> version="1.0.0"
>>> updateSequence="0"
>>> xmlns="http://www.opengis.net/wfs"
>>> http://schemas.opengis.net/wfs/1.0.0/WFS-capabilities.xsd">
>>> <!-- MapServer version 6.0.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
>>> SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=CAIRO SUPPORTS=OPENGL
>>> SUPPORTS=FREETYPE SUPPORTS=ICONV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER
>>> SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
>>> SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI
>>> SUPPORTS=THREADS SUPPORTS=GEOS INPUT=POSTGIS INPUT=OGR INPUT=GDAL
>>> INPUT=SHAPEFILE -->
>>> <Service>
>>> <Name>MapServer WFS</Name>
>>> <Title>Amtliche Vermessung</Title>
>>> <Abstract>Die amtliche Vermessung nach DM01 Darstellung als WMS
>>> Dienst für MapFish Projekte</Abstract>
>>> <OnlineResource>http://c2cpc89.camptocamp.com/sbrunner/mapserv?</OnlineResource>
>>> </Service>
>>> <Capability>
>>> <Request>
>>> <GetCapabilities>
>>> <DCPType>
>>> <HTTP>
>>> <Get
>>> onlineResource="http://c2cpc89.camptocamp.com/sbrunner/mapserv?"
>>> </HTTP>
>>> </DCPType>
>>> <DCPType>
>>> <HTTP>
>>> <Post
>>> onlineResource="http://c2cpc89.camptocamp.com/sbrunner/mapserv?" />
>>> </HTTP>
>>> </DCPType>
>>> </GetCapabilities>
>>> <DescribeFeatureType>
>>> <SchemaDescriptionLanguage>
>>> <XMLSCHEMA/>
>>> </SchemaDescriptionLanguage>
>>> <DCPType>
>>> <HTTP>
>>> <Get
>>> </HTTP>
>>> </DCPType>
>>> <DCPType>
>>> <HTTP>
>>> <Post
>>> </HTTP>
>>> </DCPType>
>>> </DescribeFeatureType>
>>> <GetFeature>
>>> <ResultFormat>
>>> <GML2/>
>>> </ResultFormat>
>>> <DCPType>
>>> <HTTP>
>>> <Get
>>> </HTTP>
>>> </DCPType>
>>> <DCPType>
>>> <HTTP>
>>> <Post
>>> </HTTP>
>>> </DCPType>
>>> </GetFeature>
>>> </Request>
>>> </Capability>
>>> <FeatureTypeList>
>>> <Operations>
>>> <Query/>
>>> </Operations>
>>> <FeatureType>
>>> <Name>Liegenschaft_Query</Name>
>>> <Title>Liegenschaft_Query</Title>
>>> <SRS>epsg:21781</SRS>
>>> <LatLongBoundingBox minx="620000" miny="218000" maxx="690000"
>>> maxy="278000" />
>>> </FeatureType>
>>> <FeatureType>
>>> <Name>Liegenschaft_Query_ALL</Name>
>>> <Title>Liegenschaft_Query_ALL</Title>
>>> maxy="278000" />
>>> </FeatureType>
>>> </FeatureTypeList>
>>> <ogc:Filter_Capabilities>
>>> <ogc:Spatial_Capabilities>
>>> <ogc:Spatial_Operators>
>>> <ogc:Equals/>
>>> <ogc:Disjoint/>
>>> <ogc:Touches/>
>>> <ogc:Within/>
>>> <ogc:Overlaps/>
>>> <ogc:Crosses/>
>>> <ogc:Intersect/>
>>> <ogc:Contains/>
>>> <ogc:DWithin/>
>>> <ogc:BBOX/>
>>> </ogc:Spatial_Operators>
>>> </ogc:Spatial_Capabilities>
>>> <ogc:Scalar_Capabilities>
>>> <ogc:Logical_Operators />
>>> <ogc:Comparison_Operators>
>>> <ogc:Simple_Comparisons />
>>> <ogc:Like />
>>> <ogc:Between />
>>> </ogc:Comparison_Operators>
>>> </ogc:Scalar_Capabilities>
>>> </ogc:Filter_Capabilities>
>>> </WFS_Capabilities>
>>> describefeaturetype [6]:
>>> <schema
>>> targetNamespace="http://mapserver.gis.umn.edu/mapserver"
>>> xmlns:xsd="http://www.w3.org/2001/XMLSchema"
>>> xmlns="http://www.w3.org/2001/XMLSchema"
>>> elementFormDefault="qualified" version="0.1" >
>>> <import namespace="http://www.opengis.net/gml"
>>> schemaLocation="http://schemas.opengis.net/gml/2.1.2/feature.xsd"
>>> <element name="Liegenschaft_Query"
>>> type="ms:Liegenschaft_QueryType"
>>> substitutionGroup="gml:_Feature" />
>>> <complexType name="Liegenschaft_QueryType">
>>> <complexContent>
>>> <extension base="gml:AbstractFeatureType">
>>> <sequence>
>>> <element name="geom" type="gml:PolygonPropertyType"
>>> minOccurs="0" maxOccurs="1"/>
>>> <element name="oid" type="string"/>
>>> <element name="nummer" type="Character"/>
>>> </sequence>
>>> </extension>
>>> </complexContent>
>>> </complexType>
>>> </schema>
>>> camptocamp.com
>>> mapfish.org
>>> mapserver-users mailing list
>>> mapserver-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> camptocamp.com
> mapfish.org
camptocamp.com
mapfish.org
