[mapserver-users] Problem GetFeature with geom filter on WFS
Steve Lime
sdlime at gmail.com
Sat Jul 30 12:20:58 EDT 2011
The filter encoding code only translates certain things into native SQL, the rest is handled in a uniform way within MapServer. Hopefully this will change over time and more processing will be moved to the database but there hasn't been time to do that yet, maybe for 6.2.
PostGIS should be returning an appropriate set of candidate features for MapServer to perform additional filtering. Shapefiles work the same way. If you look at the SQL executed by Postgres you should see all of the matching features plus a few more.
Steve
Sent from my iPad
On Jul 28, 2011, at 9:18 AM, Stéphane Brunner <stephane.brunner at camptocamp.com> wrote:
> Hello,
> I log the sql request on spatial filter and I have this:
> select "oid","nummer","gemeinde","gueltigkeit","flgrundb","quote","eigentuemer","adresse_lang",encode(ST_AsBinary(ST_Force_2D("geom"),'NDR'),'hex')
> as geom,"oid" from (SELECT oid, t1.geom, t1.nummer, t2.gemeinde,
> t1.gueltigkeit1_txt as gueltigkeit, t2.flgrundb, ((t2.zaehler::text ||
> '/'::text) || t2.nenner::text) AS quote, t2.eigentuemer,
> (((t2.adresse::text || ', '::text) || t2.plz::text) || ' '::text) ||
> t2.ort::text AS adresse_lang FROM av.liegenschaften_liegenschaft_area
> as t1, av.view_gemlis_geomaste_parzelle as t2 WHERE t1.gdid = t2.gdeid
> and t1.nummer = t2.parznr::text) AS foo where geom &&
> GeomFromText('POLYGON((620000 218000,620000 278000,690000
> 278000,690000 218000,620000 218000))',-1) limit 100
> I didn't see any postggis filter than I try to do a spatial filter on
> one of the 100 first results
> Than I have a correct result ...
> Than why mapserver doesn't use postgis spatial filter ? Does I miss something ?
> Thank-you in advance
> Stéphane Brunner
> 2011/7/26 Stéphane Brunner <stephane.brunner at camptocamp.com>:
>> Hello,
>> I just test it with a shape file, and it's working...
>> I will investigate a little bit more to know why it's not working with postgres.
>> Sincerely
>> Stéphane Brunner
>> 2011/7/25 Steve Lime <sdlime at gmail.com>:
>>> Never mind on version, I saw 6.0.0 in the response... ;-) Steve
>>> On Mon, Jul 25, 2011 at 6:19 AM, Stéphane Brunner
>>>> Hello,
>>>> I have the mapfile [0]. when I done a GetFeature on the nummer [1] I
>>>> have 4 results [2] (with duplicate but it's an other issue).
>>>> When I done a spatial filter [3] I have no results [4] but I should
>>>> have at least one result ...
>>>> Thanks in advance for having a look on this issue.
>>>> Sincerely yours
>>>> Stéphane Brunner
>>>> Following: specified, GetCapabilities [5], describefeaturetype [6].
>>>> mapfile [0]:
>>>> MAP
>>>> NAME "map"
>>>> EXTENT 620000 218000 690000 278000
>>>> UNITS METERS
>>>> IMAGETYPE jpeg
>>>> RESOLUTION 72
>>>> DEFRESOLUTION 72
>>>> IMAGECOLOR 255 255 255
>>>> STATUS ON
>>>> FONTSET "fonts.conf"
>>>> SYMBOLSET "symbole.sym"
>>>> MAXSIZE 5000
>>>> PROJECTION
>>>> "init=epsg:21781"
>>>> END
>>>> # Used by overlays
>>>> OUTPUTFORMAT
>>>> NAME png256
>>>> DRIVER AGG/PNG
>>>> MIMETYPE "image/png256"
>>>> IMAGEMODE RGBA
>>>> EXTENSION "png"
>>>> FORMATOPTION "INTERLACE=OFF"
>>>> FORMATOPTION "QUANTIZE_FORCE=ON"
>>>> FORMATOPTION "QUANTIZE_DITHER=OFF"
>>>> FORMATOPTION "QUANTIZE_COLORS=256"
>>>> END
>>>> OUTPUTFORMAT
>>>> NAME png
>>>> DRIVER AGG/PNG
>>>> MIMETYPE "image/png"
>>>> IMAGEMODE RGBA
>>>> EXTENSION "png"
>>>> END
>>>> WEB
>>>> METADATA
>>>> "ows_title" "map"
>>>> "ows_srs" "epsg:21781"
>>>> "ows_encoding" "UTF-8"
>>>> "wms_feature_info_mime_type" "application/vnd.ogc.gml"
>>>> "wms_enable_request" "*"
>>>> "ows_enable_request" "*"
>>>> "gml_include_items" "all"
>>>> "gml_featureid" "id"
>>>> "wfs_title" "map"
>>>> "wfs_srs" "epsg:21781"
>>>> END
>>>> IMAGEPATH '/var/tmp/'
>>>> END
>>>> LEGEND
>>>> IMAGECOLOR 240 240 240
>>>> LABEL
>>>> FONT arial
>>>> ANTIALIAS true
>>>> TYPE truetype
>>>> SIZE 9
>>>> COLOR 0 0 0
>>>> END
>>>> END
>>>> LAYER
>>>> NAME "Liegenschaft_Query"
>>>> TYPE POLYGON
>>>> STATUS ON
>>>> TEMPLATE fooOnlyForWMSGetFeatureInfo
>>>> CONNECTIONTYPE postgis
>>>> PROCESSING "CLOSE_CONNECTION=DEFER"
>>>> CONNECTION "user=www-data password=www-data dbname=dev host=localhost"
>>>> DATA "geom from (SELECT oid, t1.geom, t1.nummer FROM
>>>> av.view_i_liegenschaft_all AS t1) AS foo using unique oid using
>>>> SRID=-1"
>>>> # GROUP "TOPIC_Liegenschaften_LN"
>>>> METADATA
>>>> "ows_title" "Liegenschaft_Query"
>>>> "id_attribute_string" "oid"
>>>> "ows_featureid" "oid"
>>>> "ows_geometries" "geom"
>>>> "ows_geom_type" "polygon"
>>>> "query_returned_attributes" "nummer"
>>>> "gml_include_items" "oid,nummer,geom"
>>>> "gml_geometries" "geom"
>>>> "gml_geom_type" "polygon"
>>>> "gml_nummer_type" "Character"
>>>> #"gml_groups" "TOPIC_Liegenschaften_LN"
>>>> "gml_featureid" "oid"
>>>> "wfs_title" "Liegenschaft_Query"
>>>> END
>>>> DUMP TRUE
>>>> PROJECTION
>>>> "init=epsg:21781"
>>>> END
>>>> CLASS
>>>> NAME "Liegenschaft"
>>>> STYLE
>>>> SYMBOL "circle"
>>>> SIZE 3
>>>> OUTLINECOLOR 0 0 0
>>>> END
>>>> END
>>>> END
>>>> END
>>>> query on the nummer [1]:
>>>> <wfs:GetFeature xmlns:wfs="http://www.opengis.net/wfs" service="WFS"
>>>> version="1.0.0" maxFeatures="100"
>>>> xsi:schemaLocation="http://www.opengis.net/wfs
>>>> http://schemas.opengis.net/wfs/1.0.0/WFS-transaction.xsd"
>>>> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
>>>> <wfs:Query typeName="feature:Liegenschaft_Query"
>>>> xmlns:feature="http://mapserver.gis.umn.edu/mapserver">
>>>> <ogc:Filter xmlns:ogc="http://www.opengis.net/ogc">
>>>> <ogc:PropertyIsEqualTo>
>>>> <ogc:PropertyName>nummer</ogc:PropertyName>
>>>> <ogc:Literal>3634</ogc:Literal>
>>>> </ogc:PropertyIsEqualTo>
>>>> </ogc:Filter>
>>>> </wfs:Query>
>>>> </wfs:GetFeature>
>>>> response on the nummer [2]:
>>>> <?xml version='1.0' encoding="UTF-8" ?>
>>>> <wfs:FeatureCollection
>>>> xmlns:ms="http://mapserver.gis.umn.edu/mapserver"
>>>> xmlns:gml="http://www.opengis.net/gml"
>>>> http://schemas.opengis.net/wfs/1.0.0/WFS-basic.xsd
>>>> http://c2cpc89.camptocamp.com/sbrunner/mapserv?SERVICE=WFS&VERSION=1.0.0&REQUEST=DescribeFeatureType&TYPENAME=feature:Liegenschaft_Query&OUTPUTFORMAT=XMLSCHEMA">
>>>> <gml:boundedBy>
>>>> <gml:Box srsName="EPSG:21781">
>>>> <gml:coordinates>661054.808000,244611.321000
>>>> 663053.704000,244888.622000</gml:coordinates>
>>>> </gml:Box>
>>>> </gml:boundedBy>
>>>> <gml:featureMember>
>>>> <ms:Liegenschaft_Query fid="Liegenschaft_Query.2380997">
>>>> <gml:boundedBy>
>>>> <gml:coordinates>661054.808000,244854.251000
>>>> 661088.687000,244888.622000</gml:coordinates>
>>>> </gml:Box>
>>>> </gml:boundedBy>
>>>> <ms:geom>
>>>> <gml:Polygon srsName="EPSG:21781">
>>>> <gml:outerBoundaryIs>
>>>> <gml:LinearRing>
>>>> <gml:coordinates>661076.579000,244888.622000
>>>> 661054.808000,244875.484000 661062.744000,244858.448000
>>>> 661064.653000,244854.251000 661088.687000,244869.173000
>>>> 661076.579000,244888.622000 </gml:coordinates>
>>>> </gml:LinearRing>
>>>> </gml:outerBoundaryIs>
>>>> </gml:Polygon>
>>>> </ms:geom>
>>>> <ms:oid>2380997</ms:oid>
>>>> <ms:nummer>3634</ms:nummer>
>>>> </ms:Liegenschaft_Query>
>>>> </gml:featureMember>
>>>> <gml:featureMember>
>>>> <gml:boundedBy>
>>>> </gml:Box>
>>>> </gml:boundedBy>
>>>> <ms:geom>
>>>> <gml:LinearRing>
>>>> </gml:LinearRing>
>>>> </gml:Polygon>
>>>> </ms:geom>
>>>> <gml:featureMember>
>>>> <ms:Liegenschaft_Query fid="Liegenschaft_Query.2384539">
>>>> <gml:boundedBy>
>>>> <gml:coordinates>663017.565000,244611.321000
>>>> 663053.704000,244650.084000</gml:coordinates>
>>>> </gml:Box>
>>>> </gml:boundedBy>
>>>> <ms:geom>
>>>> <gml:LinearRing>
>>>> <gml:coordinates>663017.565000,244635.722000
>>>> 663033.235000,244611.321000 663045.949000,244619.485000
>>>> 663053.704000,244626.417000 663034.337000,244650.084000
>>>> 663017.565000,244635.722000 </gml:coordinates>
>>>> </gml:LinearRing>
>>>> </gml:Polygon>
>>>> </ms:geom>
>>>> <ms:oid>2384539</ms:oid>
>>>> <gml:featureMember>
>>>> <gml:boundedBy>
>>>> </gml:Box>
>>>> </gml:boundedBy>
>>>> <ms:geom>
>>>> <gml:LinearRing>
>>>> </gml:LinearRing>
>>>> </gml:Polygon>
>>>> </ms:geom>
>>>> </wfs:FeatureCollection>
>>>> query with spatial filter [3]:
>>>> <ogc:Intersects>
>>>> <ogc:PropertyName>geom</ogc:PropertyName>
>>>> <gml:Point xmlns:gml="http://www.opengis.net/gml" srsName="EPSG:21781">
>>>> <gml:coordinates decimal="." cs="," ts="
>>>> ">661070.024,244872.084</gml:coordinates>
>>>> </gml:Point>
>>>> </ogc:Intersects>
>>>> </ogc:Filter>
>>>> </wfs:Query>
>>>> </wfs:GetFeature>
>>>> response with spatial filter [4]:
>>>> <gml:boundedBy>
>>>> <gml:null>missing</gml:null>
>>>> </gml:boundedBy>
>>>> GetCapabilities [5]:
>>>> <WFS_Capabilities
>>>> version="1.0.0"
>>>> updateSequence="0"
>>>> xmlns="http://www.opengis.net/wfs"
>>>> http://schemas.opengis.net/wfs/1.0.0/WFS-capabilities.xsd">
>>>> <!-- MapServer version 6.0.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
>>>> SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=CAIRO SUPPORTS=OPENGL
>>>> SUPPORTS=FREETYPE SUPPORTS=ICONV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER
>>>> SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
>>>> SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI
>>>> SUPPORTS=THREADS SUPPORTS=GEOS INPUT=POSTGIS INPUT=OGR INPUT=GDAL
>>>> INPUT=SHAPEFILE -->
>>>> <Service>
>>>> <Name>MapServer WFS</Name>
>>>> <Title>Amtliche Vermessung</Title>
>>>> <Abstract>Die amtliche Vermessung nach DM01 Darstellung als WMS
>>>> Dienst für MapFish Projekte</Abstract>
>>>> <OnlineResource>http://c2cpc89.camptocamp.com/sbrunner/mapserv?</OnlineResource>
>>>> </Service>
>>>> <Capability>
>>>> <Request>
>>>> <GetCapabilities>
>>>> <DCPType>
>>>> <HTTP>
>>>> <Get
>>>> onlineResource="http://c2cpc89.camptocamp.com/sbrunner/mapserv?"
>>>> </HTTP>
>>>> </DCPType>
>>>> <DCPType>
>>>> <HTTP>
>>>> <Post
>>>> onlineResource="http://c2cpc89.camptocamp.com/sbrunner/mapserv?" />
>>>> </HTTP>
>>>> </DCPType>
>>>> </GetCapabilities>
>>>> <DescribeFeatureType>
>>>> <SchemaDescriptionLanguage>
>>>> <XMLSCHEMA/>
>>>> </SchemaDescriptionLanguage>
>>>> <DCPType>
>>>> <HTTP>
>>>> <Get
>>>> </HTTP>
>>>> </DCPType>
>>>> <DCPType>
>>>> <HTTP>
>>>> <Post
>>>> </HTTP>
>>>> </DCPType>
>>>> </DescribeFeatureType>
>>>> <GetFeature>
>>>> <ResultFormat>
>>>> <GML2/>
>>>> </ResultFormat>
>>>> <DCPType>
>>>> <HTTP>
>>>> <Get
>>>> </HTTP>
>>>> </DCPType>
>>>> <DCPType>
>>>> <HTTP>
>>>> <Post
>>>> </HTTP>
>>>> </DCPType>
>>>> </GetFeature>
>>>> </Request>
>>>> </Capability>
>>>> <FeatureTypeList>
>>>> <Operations>
>>>> <Query/>
>>>> </Operations>
>>>> <FeatureType>
>>>> <Name>Liegenschaft_Query</Name>
>>>> <Title>Liegenschaft_Query</Title>
>>>> <SRS>epsg:21781</SRS>
>>>> <LatLongBoundingBox minx="620000" miny="218000" maxx="690000"
>>>> maxy="278000" />
>>>> </FeatureType>
>>>> <FeatureType>
>>>> <Name>Liegenschaft_Query_ALL</Name>
>>>> <Title>Liegenschaft_Query_ALL</Title>
>>>> maxy="278000" />
>>>> </FeatureType>
>>>> </FeatureTypeList>
>>>> <ogc:Filter_Capabilities>
>>>> <ogc:Spatial_Capabilities>
>>>> <ogc:Spatial_Operators>
>>>> <ogc:Equals/>
>>>> <ogc:Disjoint/>
>>>> <ogc:Touches/>
>>>> <ogc:Within/>
>>>> <ogc:Overlaps/>
>>>> <ogc:Crosses/>
>>>> <ogc:Intersect/>
>>>> <ogc:Contains/>
>>>> <ogc:DWithin/>
>>>> <ogc:BBOX/>
>>>> </ogc:Spatial_Operators>
>>>> </ogc:Spatial_Capabilities>
>>>> <ogc:Scalar_Capabilities>
>>>> <ogc:Logical_Operators />
>>>> <ogc:Comparison_Operators>
>>>> <ogc:Simple_Comparisons />
>>>> <ogc:Like />
>>>> <ogc:Between />
>>>> </ogc:Comparison_Operators>
>>>> </ogc:Scalar_Capabilities>
>>>> </ogc:Filter_Capabilities>
>>>> </WFS_Capabilities>
>>>> describefeaturetype [6]:
>>>> <schema
>>>> targetNamespace="http://mapserver.gis.umn.edu/mapserver"
>>>> xmlns:xsd="http://www.w3.org/2001/XMLSchema"
>>>> xmlns="http://www.w3.org/2001/XMLSchema"
>>>> elementFormDefault="qualified" version="0.1" >
>>>> <import namespace="http://www.opengis.net/gml"
>>>> schemaLocation="http://schemas.opengis.net/gml/2.1.2/feature.xsd"
>>>> <element name="Liegenschaft_Query"
>>>> type="ms:Liegenschaft_QueryType"
>>>> substitutionGroup="gml:_Feature" />
>>>> <complexType name="Liegenschaft_QueryType">
>>>> <complexContent>
>>>> <extension base="gml:AbstractFeatureType">
>>>> <sequence>
>>>> <element name="geom" type="gml:PolygonPropertyType"
>>>> minOccurs="0" maxOccurs="1"/>
>>>> <element name="oid" type="string"/>
>>>> <element name="nummer" type="Character"/>
>>>> </sequence>
>>>> </extension>
>>>> </complexContent>
>>>> </complexType>
>>>> </schema>
>>>> camptocamp.com
>>>> mapfish.org
>>>> _______________________________________________
>>>> mapserver-users mailing list
>>>> mapserver-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>> camptocamp.com
>> mapfish.org
> camptocamp.com
> mapfish.org
