[mapserver-users] Re: Is it posible to substitute a value from table for width of line
    prab.raja
    prab.raja at gmail.com
    Wed Jun  1 01:58:37 PDT 2011
Below is the mapserv.exe -v output.
It shows MapServer version 5.2.1 only.
MapServer version 5.2.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=PDF
 OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE
SUPPORTS=ICO
NV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
SUPPORTS=WFS_SERVER
SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI
SUP
PORTS=THREADS SUPPORTS=GEOS SUPPORTS=RGBA_PNG INPUT=JPEG INPUT=POSTGIS
INPUT=OGR
 INPUT=GDAL INPUT=SHAPEFILE
On Wed, Jun 1, 2011 at 2:24 PM, thomas bonfort [via OSGeo.org] <
ml-node+6426114-1083275088-338562 at n2.nabble.com> wrote:
> then make sure you are actually using 5.2.1 and not an older version
> On Wed, Jun 1, 2011 at 10:47, prab.raja <[hidden email]<http://user/SendEmail.jtp?type=node&node=6426114&i=0>>
> wrote:
> > yes.
> > Below is the style copied from my Map file.
> >         STYLE
> >             COLOR 0 140 70
> >             WIDTH [gid]
> >          END
> > On Wed, Jun 1, 2011 at 2:12 PM, thomas bonfort [via OSGeo.org] <[hidden
> > email]> wrote:
> >> are you using the exact syntax of your first example, i.e. "WIDTH [gid]"
> >> On Wed, Jun 1, 2011 at 10:27, prab.raja <[hidden email]> wrote:
> >> > But when I tried this mapserver gives error message as "getInteger():
> >> > Symbol
> >> > definition error. Parsing error near (gid)".
> >> > I am using MapServer version 5.2.1.
> >> > On Wed, Jun 1, 2011 at 1:48 PM, Havard Tveite [via OSGeo.org] <[hidden
> >> > email]> wrote:
> >> >> According to <URL: <a
> >> >> href="<a href="http://www.mapserver.org/mapfile/style.html ">
> http://www.mapserver.org/mapfile/style.html "><a href="
> http://www.mapserver.org/mapfile/style.html >
> >> >> that should be possible.
> >> >> Håvard
> >> >> On 6/1/2011 8:09 AM, prab.raja wrote:
> >> >> > Hi,
> >> >> > I would like to know if it's posible to draw line layer with
> variable
> >> >> > width
> >> >> > from database table.
> >> >> > Something like this?
> >> >> > LAYER
> >> >> >        NAME line_layer
> >> >> >        CONNECTIONTYPE postgis
> >> >> >        CONNECTION "user=postgres password=****** dbname=shpdb
> >> >> > host=localhost
> >> >> > port=5432"
> >> >> >        DATA "the_geom FROM  (SELECT gid, the_geom FROM line_layer)
> >> >> >           AS SUBQUERY using unique gid"
> >> >> >        PROCESSING "CLOSE_CONNECTION=DEFER"
> >> >> >        TYPE line
> >> >> >        OPACITY 100
> >> >> >        STATUS Off
> >> >> >        CLASS
> >> >> >           STYLE
> >> >> >              COLOR 0 140 70
> >> >> >              WIDTH [gid]
> >> >> >           END
> >> >> >        END
> >> >> >     END
> >> >> > View this message in context:
> http://osgeo-org.1803224.n2.nabble.com/Is-it-posible-to-substitute-a-value-from-table-for-width-of-line-tp6425708p6425708.html
> >> >> > Sent from the Mapserver - User mailing list archive at Nabble.com.
> >> >> > _______________________________________________
> >> >> > mapserver-users mailing list
> >> >> > [hidden email]
> >> >> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
> >> >> Håvard Tveite
> >> >> Department of Mathematical Sciences and Technology, UMB
> >> >> Drøbakveien 31, POBox 5003, N-1432 Ås, NORWAY
> >> >> Phone: +47 64965483 Fax: +47 64965401 http://www.umb.no/imt/
> >> >> [hidden email]
> >> >> If you reply to this email, your message will be added to the
> >> >> discussion
> >> >> below:
> http://osgeo-org.1803224.n2.nabble.com/Is-it-posible-to-substitute-a-value-from-table-for-width-of-line-tp6425708p6426034.html
> >> >> To unsubscribe from Is it posible to substitute a value from table
> for
> >> >> width of line, click here.
> >> > Regards,
> >> > Prabu Raja
> >> > View this message in context: Re: Is it posible to substitute a value
> >> > from
> >> > [hidden email]
> >> [hidden email]
> >> If you reply to this email, your message will be added to the discussion
> >> below:
> http://osgeo-org.1803224.n2.nabble.com/Is-it-posible-to-substitute-a-value-from-table-for-width-of-line-tp6425708p6426084.html
> >> To unsubscribe from Is it posible to substitute a value from table for
> > Regards,
> > Prabu Raja
> from
> > [hidden email] <http://user/SendEmail.jtp?type=node&node=6426114&i=1>
> [hidden email] <http://user/SendEmail.jtp?type=node&node=6426114&i=2>
> below:
> http://osgeo-org.1803224.n2.nabble.com/Is-it-posible-to-substitute-a-value-from-table-for-width-of-line-tp6425708p6426114.html
> width of line, click here<http://osgeo-org.1803224.n2.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=6425708&code=cHJhYi5yYWphQGdtYWlsLmNvbXw2NDI1NzA4fDM2NjU1NDU1NA==>.
Regards,
Prabu Raja
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Is-it-posible-to-substitute-a-value-from-table-for-width-of-line-tp6425708p6426123.html
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110601/7ea7fde2/attachment.htm>
More information about the MapServer-users
