[mapserver-users] where is the line ?
Tonton
to.tonton at gmail.com
Mon Jun 6 05:51:10 EDT 2011
but the file is' nt be modify from janary
#7
SYMBOL
NAME 'circle'
TYPE ELLIPSE
FILLED TRUE
POINTS
1 1
END
END
On Mon, Jun 6, 2011 at 11:39 AM, Prabu Raja <prab.raja at gmail.com> wrote:
> Ok. You have included the symbols using "SYMBOLSET" keyword.
> Problem might be with symbol named 7 or seventh symbol in that
> file(./symbols/symbols.txt).
> On Mon, Jun 6, 2011 at 3:01 PM, Tonton <to.tonton at gmail.com> wrote:
>> ---------- Forwarded message ----------
>> From: Prabu Raja <prab.raja at gmail.com>
>> Post your mapfile content, show that we can check what's wrong.
>> euh
>> #debut du fichier
>> MAP
>> NAME '28811'
>> SIZE 640 480
>> UNITS METERS
>> FONTSET './fonts/fonts.txt'
>> SYMBOLSET './symbols/symbols.txt'
>> EXTENT 4.65883541107178 45.5676007678223 5.06030035018921 45.9033622741699
>> DEBUG ON
>> CONFIG "MS_ERRORFILE" "/var/www/tmp/ms_error.txt" #definition de la
>> projection de la carte
>> PROJECTION
>> "init=epsg:4326"
>> END #Projection
>> IMAGETYPE "PNG24"
>> # Debut de la section OUTPUTFORMAT
>> OUTPUTFORMAT
>> NAME png
>> DRIVER "GD/PNG"
>> MIMETYPE "image/png"
>> IMAGEMODE PC256
>> EXTENSION 'png'
>> END
>> # debut de la section Web
>> WEB
>> MINSCALEDENOM 1000
>> MAXSCALEDENOM 1550000
>> #Modifier cette ligne selon votre installation
>> IMAGEPATH "/var/www/tmp/"
>> IMAGEURL "./tmp/"
>> METADATA
>> ows_TITLE "28811"
>> ows_ONLINERESOURCE "
>> http://192.168.12.60/cgi-bin/mapserv?map=/var/www/mapfile/28811.map"
>> "ows_SRS" "EPSG:4326 "
>> ows_ABSTRACT "OWS Geomod webservice "
>> ows_ACCESSCONSTRAINTS "None"
>> END #METADATA
>> LOG "./tmp/web.log"
>> END #WEB
>> # debut de Definition de la Couche
>> LAYER
>> CONNECTIONTYPE postgis
>> CONNECTION "host=localhost dbname=DBname user=USER password=PWD
>> port=5432"
>> DATA "geometry FROM tablename"
>> NAME "28811"
>> TYPE POINT
>> DUMP TRUE
>> TRANSPARENCY ALPHA
>> LABELCACHE ON
>> METADATA
>> ows_TITLE "28811"
>> "ows_SRS" "EPSG:4326"
>> "gml_featureid" "gid" ##required
>> "ows_include_items" "nom_stt"
>> "ows_typename" "28811"
>> END #METADATA
>> LABELITEM nom_stt
>> STATUS ON
>> Class
>> NAME "28811"
>> STYLE
>> SYMBOL 7
>> SIZE 2
>> OUTLINECOLOR 255 255 255
>> COLOR 192 192 192
>> END #Style
>> LABEL
>> FONT arial
>> TYPE truetype
>> ANTIALIAS true
>> MAXSCALEDENOM 92500
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> Regards,
> Prabu Raja
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110606/4114412b/attachment-0001.html
