[mapserver-users] mapserver WMS
Marco Bagni
m.bagni at marcobagni.com
Mon Jun 27 06:51:23 EDT 2011
very likely there is a problem with your DATA declaration since, as far as
I know you have to put the name of the coverage enclosed within quotes and
complete with the extension like:
DATA 'popplace.shp'
On the other side this MAP file looks wery "skinny".
Here is an example of a MAP "template" I am using with my system for a
vector coverage in SHP format:
###<<<START>>>6493f0c28e6856b_VL2
LAYER
NAME '6493f0c28e6856b_VL2'
TYPE LINE
DATA 'absolute path to the location of the shape file like
/usr/local/web/gweb/gis-root/level_2/cartographic_background/administrative_boundaries/district_limit/6493f0c28e6856b/reg2010_s.shp'
DUMP true
HEADER 'this is optional and allows to return the results of an identify
in html format but in order to have this you have to declare
"'wms_feature_info_mime_type' 'text/html'" in the WEB METADATA section
of the MAP part of the map file, that at the beginning of the file
:/usr/local/web/gweb/gis-root/level_2/cartographic_background/administrative_boundaries/district_limit/6493f0c28e6856b/template_header.html'
TEMPLATE 'this MUST be filled with something also some gibberish like
"templatestuff" or the absolute path to a real HTML file like:
/usr/local/web/gweb/gis-root/level_2/cartographic_background/administrative_boundaries/district_limit/6493f0c28e6856b/template_query.html'
FOOTER 'applies the same comment of the HEADER token
/usr/local/web/gweb/gis-root/level_2/cartographic_background/administrative_boundaries/district_limit/6493f0c28e6856b/template_footer.html'
EXTENT 313361.0014 3933878.5013 1312106.7514 5220491.2513
METADATA
'wfs_title' 'VL_2: Regioni' # this name is the name displayed in the
WMS clients
'ows_title' 'VL_2: Regioni'
'ows_abstract' 'UserData:; ;__System___; Sector: Cartographic
Background; Category: Administrative Boundaries; Table: District
Limit; Date_from: 0000-00-00; Date_to: 0000-00-00; DataType: LINE'
'ows_srs' 'EPSG:4326'
'ows_include_items' 'all'
'ows_types' 'auto'
'gml_featureid' 'ID' # this stuff is for WFS queries and contains
the list of the coverage fields that must be exported
'gml_include_items' 'all'
'gml_types' 'auto'
'gml_COD_REG_type' 'Integer'
'gml_NOME_REG_type' 'String'
END
STATUS OFF
TRANSPARENCY 100
PROJECTION
'proj=utm'
'ellps=WGS84'
'datum=WGS84'
'zone=32'
'north'
'units=m'
'no_defs'
END
# In this field the user can insert the commands to display the map
# accordingly with a classification based on the value of one or more fields
# following the MAP Server syntax like in the following example:
# CLASSITEM 'Code'
# CLASS
# NAME '1.000 < Code < 13.250'
# EXPRESSION ( ([Code] >= 1.000) AND ([Code] <= 13.250) )
# STYLE
# WIDTH 1
# OUTLINECOLOR 0 0 0
# COLOR 0 255 0
# END
# END
# CLASS
# NAME '13.250 < Code < 25.500'
# EXPRESSION ( ([Code] >= 13.250) AND ([Code] <= 25.500) )
# STYLE
# WIDTH 1
# COLOR 0 191 64
# END
# END
CLASS
NAME 'VL_2: Regioni'
TEXT ([NOME_REG])
STYLE
WIDTH 1
OUTLINECOLOR 0 0 0
COLOR 127 127 127
END
LABEL # the field used to display the label is declared in the TEXT
token few lines before
FONT 'arial'
TYPE bitmap
COLOR 0 0 0
OUTLINECOLOR 255 255 255
POSITION auto
SIZE tiny
WRAP '@'
END
END
END
###<<<END>>>6493f0c28e6856b_VL2
Hoping that this will be of some help.
Cheers
Marco Bagni
On Mon, June 27, 2011 9:32 am, Sila Khan wrote:
> i followed the same pattern of mapfile for accessing maps through wms
> and when i start it in browser it gives Error like this
> loadHashTable(): Unknown identifier. Parsing error near (TYPE):(line 47)
> when i modify the recommended line it goes to an other line with same
> Error
> plz help me to rectify the Error
> NAME "WMS-test"STATUS ONSIZE 400 300SYMBOLSET ../etc/symbols.symEXTENT
> -2200000 -712631 3072800 3840000UNITS METERSSHAPEPATH
> "../data"IMAGECOLOR 255 255 255FONTSET ../etc/fonts.txt
> WEB
> IMAGEPATH "/ms4w/tmp/ms_tmp/"
> IMAGEURL "/ms_tmp/"
> METADATA
> "wms_title" "WMS Demo Server" ##required
> "wms_onlineresource" "http://yourpath/cgi-bin/mapserv.exe?"
> ##required
> "wms_srs" "EPSG:42304 EPSG:42101 EPSG:4269 EPSG:4326"
> ##recommended
> ENDEND
> PROJECTION
> "init=epsg:42304" ##requiredEND
> ## Start of layer definitions#
> LAYER
> NAME "park"
> METADATA
> "wms_title" "Parks" ##required
> END
> TYPE POLYGON
> STATUS OFF
> DATA park
> PROJECTION
> "init=epsg:42304" ##recommended
> END
> CLASS
> NAME "Parks"
> STYLE
> COLOR 200 255 0
> OUTLINECOLOR 120 120 120
> END
> ENDEND # Layer
> LAYER
> NAME popplace
> METADATA
> "wms_title" "Cities" ##required
> END
> TYPE POINT
> STATUS ON
> DATA popplace
> PROJECTION
> END
> CLASS
> NAME "Cities"
> STYLE
> SYMBOL 2
> SIZE 8
> COLOR 0 0 0
> END
> ENDEND # Layer
> END # Map File
> mapserver-users at lists.osgeo.org
