[mapserver-users] MapServer and Guid USING UNIQUE
Roger Bedell
sylvanascent at gmail.com
Thu Mar 10 06:35:16 EST 2011
Thanks Till, however, here is the trace from the ODBC tracer, pretty obvious
what is going on:
DIAG [42000] [Microsoft][ODBC SQL Server Driver][SQL
Server]Insufficient result space to convert uniqueidentifier value to char.
(8170)
Guids generally take up 36 characters when converted to a string, and the
Select statement only has room for 20.
Since this is a SQL specific query, my guess it is being generated in the
sql spatial driver?
Roger
HSTMT 0x0589B310
UCHAR * 0x05E1A990 [ -3] "SELECT
Feature.STAsBinary(),convert(varchar(20), PKey) from MetesAndBoundsHeader
WHERE Feature.STIntersects(Geometry::STGeomFromText('POLYGON((-104.18599
29.2473266843318,-93.22438 29.2473266843318,-93.22438
41.3707663156682,-104.18599 41.3707663156682,-104.18599
29.2473266843318))',4326)) = 1 \ 0"
SDWORD -3
(8170)
On Thu, Mar 10, 2011 at 12:04 PM, adams <adams at terrestris.de> wrote:
> Dear Roger,
> if you get an empty image with no error, the first try would be to use a
> simple symbol and no expression in your layer.
> Also ensure, that your extent when querying the map is correct.
> So you make sure, that everything around your datasource is OK.
> Then use a datastring like this one:
> DATA "the_geom from (SELECT Feature from MetesAndBoundsHeader) as foo USING
> UNIQUE PKey USING SRID=4326"
> or however the geometry-column in mssql server is called ;-)
> Regards, Till
> Roger Bedell wrote:
> Good Morning.
> I am currently working with MapServer and the MSSQL Spatial driver. I am
> seeing that MS does not work with a DATA statement like this in the Map
> file:
> DATA "Feature from MetesAndBoundsHeader USING UNIQUE PKey USING SRID=4326"
> where PKey is defined like this:
> [PKey] [uniqueidentifier] DEFAULT NEWSEQUENTIALID() ROWGUIDCOL NOT NULL,
> No errors are triggered, however nothing is displayed, including all other
> layers. Is this an issue with the SQL Spatial driver or MapServer? Any ideas
> on how to fix it?
> Thanks!
> Roger Bedell
> Coordinate Solutions Inc.
> mapserver-users mailing listmapserver-users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/mapserver-users
> terrestris GmbH & Co. KG
> Irmintrudisstrasse 17
> 53111 Bonn
> Germany
> Till Adams
> Geschäftsführung
> Tel: +49 (0)228 / 962 899-52
> Fax: +49 (0)228 / 962 899-57adams at terrestris.de http://www.terrestris.de
> Amtsgericht Bonn, HRA 6835
> Komplementärin:
> terrestris Verwaltungs GmbH
> vertreten durch:
> Hinrich Paulsen, Till Adams
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110310/0b78d435/attachment.html
