[mapserver-users] MapServer and Guid USING UNIQUE
Roger Bedell
sylvanascent at gmail.com
Thu Mar 10 07:12:14 EST 2011
Thanks Tamas!
It is ticket 3722
Roger
On Thu, Mar 10, 2011 at 12:56 PM, Tamas Szekeres <szekerest at gmail.com>wrote:
> Hi Roger,
> Could you create a ticket with this issue (
> http://trac.osgeo.org/mapserver/newticket)? I'll take care of fixing this.
> Best regards,
> Tamas
> 2011/3/10 Roger Bedell <sylvanascent at gmail.com>
> Thanks Till, however, here is the trace from the ODBC tracer, pretty
>> obvious what is going on:
>> DIAG [42000] [Microsoft][ODBC SQL Server Driver][SQL
>> Server]Insufficient result space to convert uniqueidentifier value to char.
>> (8170)
>> Guids generally take up 36 characters when converted to a string, and the
>> Select statement only has room for 20.
>> Since this is a SQL specific query, my guess it is being generated in the
>> sql spatial driver?
>> Roger
>> HSTMT 0x0589B310
>> UCHAR * 0x05E1A990 [ -3] "SELECT
>> Feature.STAsBinary(),convert(varchar(20), PKey) from MetesAndBoundsHeader
>> WHERE Feature.STIntersects(Geometry::STGeomFromText('POLYGON((-104.18599
>> 29.2473266843318,-93.22438 29.2473266843318,-93.22438
>> 41.3707663156682,-104.18599 41.3707663156682,-104.18599
>> 29.2473266843318))',4326)) = 1 \ 0"
>> SDWORD -3
>> (8170)
>> On Thu, Mar 10, 2011 at 12:04 PM, adams <adams at terrestris.de> wrote:
>>> Dear Roger,
>>> if you get an empty image with no error, the first try would be to use a
>>> simple symbol and no expression in your layer.
>>> Also ensure, that your extent when querying the map is correct.
>>> So you make sure, that everything around your datasource is OK.
>>> Then use a datastring like this one:
>>> DATA "the_geom from (SELECT Feature from MetesAndBoundsHeader) as foo
>>> USING UNIQUE PKey USING SRID=4326"
>>> or however the geometry-column in mssql server is called ;-)
>>> Regards, Till
>>> Roger Bedell wrote:
>>> Good Morning.
>>> I am currently working with MapServer and the MSSQL Spatial driver. I am
>>> seeing that MS does not work with a DATA statement like this in the Map
>>> file:
>>> DATA "Feature from MetesAndBoundsHeader USING UNIQUE PKey USING
>>> SRID=4326"
>>> where PKey is defined like this:
>>> [PKey] [uniqueidentifier] DEFAULT NEWSEQUENTIALID() ROWGUIDCOL NOT NULL,
>>> No errors are triggered, however nothing is displayed, including all
>>> other layers. Is this an issue with the SQL Spatial driver or MapServer? Any
>>> ideas on how to fix it?
>>> Thanks!
>>> Roger Bedell
>>> Coordinate Solutions Inc.
>>> mapserver-users mailing listmapserver-users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/mapserver-users
>>> terrestris GmbH & Co. KG
>>> Irmintrudisstrasse 17
>>> 53111 Bonn
>>> Germany
>>> Till Adams
>>> Geschäftsführung
>>> Tel: +49 (0)228 / 962 899-52
>>> Fax: +49 (0)228 / 962 899-57adams at terrestris.de http://www.terrestris.de
>>> Amtsgericht Bonn, HRA 6835
>>> Komplementärin:
>>> terrestris Verwaltungs GmbH
>>> vertreten durch:
>>> Hinrich Paulsen, Till Adams
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110310/0409488c/attachment-0001.html
