[mapserver-users] MapServer 6.0.0-beta1 release - Please test!
Daniel Morissette
dmorissette at mapgears.com
Thu Mar 10 14:05:27 EST 2011
Hi Peter,
It is quite likely that you are using a SWIG version newer than 1.3.36.
The Java SWIG wrappers work best with SWIG 1.3.36. The MapServer source
package already contains SWIG wrappers generated using SWIG 1.3.36 so
you could use that, or if you must regenerate them then I'd suggest that
you try with SWIG 1.3.36.
Daniel
On 11-03-10 02:02 PM, Peter Hopfgartner wrote:
> While trying to build the package for CentOS 5.6, I stumble on Java support:
> + cd ../java
> + JAVA_HOME=/usr/lib/jvm/java-1.6.0
> + make interface
> mkdir -p edu/umn/gis/mapscript
> swig -java -package edu.umn.gis.mapscript -outdir edu/umn/gis/mapscript -o mapscript_wrap.c ../mapscript.i
> + make
> javac edu/umn/gis/mapscript/*.java
> gcc -fpic -c -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector --param=ssp-buffer-size=4 -m64 -mtune=generic -fPIC -Wall -DHAVE_VSNPRINTF -DNEED_STRLCPY -DNEED_STRLCAT -DNEED_STRRSTR -DUSE_PROJ -DUSE_WMS_SVR -DUSE_WMS_LYR -DUSE_WFS_SVR -DUSE_WFS_LYR -DUSE_WCS_SVR -DUSE_SOS_SVR -DUSE_JPEG -DUSE_GD_GIF -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DGD_HAS_FTEX_XSHOW -DGD_HAS_GDIMAGEGIFPTR -DGD_HAS_GETBITMAPFONTS -DGD_HAS_GET_TRUE_COLOR_PIXEL @AGG_ENABLED@ @PDF_ENABLED@ -DUSE_OGR -DUSE_GDAL -DUSE_GEOS -DUSE_ICONV -DUSE_POSTGIS -DPOSTGIS_HAS_SERVER_VERSION -DUSE_MYGIS -DUSE_THREAD -I/usr/include -Irenderers/agg/include @PDF_INC@ -I/usr/include/php/ext/ereg/ -I/usr/include/gdal -I/usr/include -I/usr/include/mysql -g -pipe -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector --param=ssp-buffer-size=4 -m64 -D_GNU_SOURCE -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -fno-strict-aliasing -fwrapv -I/usr/include -I/usr/include/libxml2 -I/usr/l
ib/jvm/java-1.6.0/include -I/usr/lib/jvm/java-1.6.0/include/linux -fno-strict-aliasing mapscript_wrap.c
> gcc: @AGG_ENABLED@: No such file or directory
> gcc: @PDF_ENABLED@: No such file or directory
> gcc: @PDF_INC@: No such file or directory
> mapscript_wrap.c: In function 'new_imageObj':
> mapscript_wrap.c:2746: warning: passing argument 1 of 'renderer->loadImageFromFile' discards qualifiers from pointer target type
> mapscript_wrap.c: In function 'Java_edu_umn_gis_mapscript_mapscriptJNI_imageObj_1getBytes':
> mapscript_wrap.c:29157: warning: pointer targets in passing argument 2 of 'SWIG_JavaArrayOutSchar' differ in signedness
> mapscript_wrap.c: In function 'Java_edu_umn_gis_mapscript_mapscriptJNI_msIO_1getStdoutBufferBytes':
> mapscript_wrap.c:43772: warning: pointer targets in passing argument 2 of 'SWIG_JavaArrayOutSchar' differ in signedness
> make: *** [mapscript_so] Error 1
> error: Bad exit status from /home/rpmbuild/rpmbuild/tmp/rpm-tmp.49448 (%build)
> RPM build errors:
> [rpmbuild at rpm-devel ~]$
> Regards,
> Peter
> R3 GIS Srl - GmbH
> http://www.r3-gis.com
> --------Daniel Morissette<dmorissette at mapgears.com> wrote--------
> Subject: [mapserver-users] MapServer 6.0.0-beta1 release - Please test!
> Date: 10.03.2011 03:48
>> The MapServer Team is pleased to announce the release of MapServer
>> 6.0.0-beta1. This is the first beta on our way to a final 6.0 release.
>> This new release introduces important changes in key components of the
>> MapServer core (rendering, query and expressions), and for this reason
>> we count on you, MapServer power users, to help test the release in your
>> respective environments and provide feedback (through the users list or
>> Trac tickets).
>> Thanks! - The MapServer Team
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
Daniel Morissette
http://www.mapgears.com/
Provider of Professional MapServer Support since 2000
