[mapserver-users] MapServer 6.0.0-beta1 release - Please test!
thomas bonfort
thomas.bonfort at gmail.com
Fri Mar 11 06:20:41 EST 2011
Andy,
yes a (beefy) video card is needed or at least wanted, as you want to
offset the calculations to the GPU. If one isn't present, you're going
to fall back to a software opengl implementation which will be orders
of magnitude slower than what AGG is going to take.
cc-ing Toby if he wants to comment further on this.
regards,
thomas
On Fri, Mar 11, 2011 at 03:02, Andy Colson <andy at squeakycode.net> wrote:
> On 03/10/2011 07:16 PM, Andy Colson wrote:
>> On 03/09/2011 08:47 PM, Daniel Morissette wrote:
>>> The MapServer Team is pleased to announce the release of MapServer
>>> 6.0.0-beta1. This is the first beta on our way to a final 6.0 release.
>> I cannot seem to get opengl to work.
>> a stacktrace of shp2img:
>> Program received signal SIGSEGV, Segmentation fault.
>> 0x00007ffff690bcab in glGetIntegerv () from /usr/lib64/libGL.so.1
>> (gdb) backtrace
>> #0 0x00007ffff690bcab in glGetIntegerv () from /usr/lib64/libGL.so.1
>> #1 0x000000000047667f in OglRenderer::OglRenderer(unsigned int, unsigned
>> int, colorObj*) ()
>> #2 0x0000000000474988 in msImageCreateOgl(int, int, outputFormatObj*,
>> colorObj*) ()
>> #3 0x000000000044cd26 in msPrepareImage ()
>> #4 0x000000000044ce75 in msDrawMap ()
>> #5 0x0000000000415067 in main ()
>> (gdb)
>> MapServer version 6.0.0-beta1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
>> SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=CAIRO SUPPORTS=OPENGL SUPPORTS=FREETYPE
>> SUPPORTS=ICONV SUPPORTS=WMS_SERVER SUPPORTS=GEOS INPUT=POSTGIS INPUT=OGR
>> INPUT=GDAL INPUT=SHAPEFILE
>> I dont need special video card and/or drivers, do I? And I'm not running
>> X. Dont need to, do I?
>> -Andy
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> To reply to myself, after some googling, it looks like yes, X is needed.
> Which kinda sucks. This is a webserver, it runs apache and postgresql. In
> a rack someplace. Doesn't even have a monitor attached. If I ever need to
> do something I ssh in.
> Its also has a crappy video card. Cuz its a server. Never thought I'd need
> good video.
> So here is my delima: do I buy a $80 video card, and run X, so I can get
> hardware accelerated maps? Is it worth it? Is it that much faster?
> How many concurrent maps can be drawn at once? If 10 people hit my website
> can all 10 images be rendered at once? Or will one run and the others error
> out? Is there an upper limit for the number of concurrent renderings?
> Any benchmarks?
> -Andy
