[mapserver-users] MapServer and Guid USING UNIQUE
Tamas Szekeres
szekerest at gmail.com
Thu Mar 17 12:16:58 EDT 2011
Roger,
Which package did you try. The -stable branches (ie:
http://vbkto.dyndns.org/sdk/PackageList.aspx?file=release-1600-gdal-1-8-mapserver-5-6.zip)
should contain the fix.
Best regards,
Tamas
2011/3/17 Roger Bedell <sylvanascent at gmail.com>
> Hi Tamas,
> I'm trying to get this working and ran into a couple snags. We are
> currently using mapscript_csharp.dll version 5.6.5 in a .NET program.
> 1) Tried to just copy just the msplugin_mssql2008.dll from your latest
> build from http://vbkto.dyndns.org/sdk/ - this didn't work, must have
> other dependencies, I didn't really think it would work.
> 2) Tried to use the latest build. Strangely, mapscript_csharp.dll doesn't
> seem to have the same objects as 5.6.5, and I got a bunch of unresolved
> references in the code.
> What do you think is the easiest way to get this working?
> Thanks,
> Roger Bedell
> Coordinate Solutions Inc.
> On Thu, Mar 10, 2011 at 12:56 PM, Tamas Szekeres <szekerest at gmail.com>wrote:
>> Hi Roger,
>> Could you create a ticket with this issue (
>> http://trac.osgeo.org/mapserver/newticket)? I'll take care of fixing
>> this.
>> Best regards,
>> Tamas
>> 2011/3/10 Roger Bedell <sylvanascent at gmail.com>
>>> Thanks Till, however, here is the trace from the ODBC tracer, pretty
>>> obvious what is going on:
>>> DIAG [42000] [Microsoft][ODBC SQL Server Driver][SQL
>>> Server]Insufficient result space to convert uniqueidentifier value to char.
>>> (8170)
>>> Guids generally take up 36 characters when converted to a string, and the
>>> Select statement only has room for 20.
>>> Since this is a SQL specific query, my guess it is being generated in the
>>> sql spatial driver?
>>> Roger
>>> HSTMT 0x0589B310
>>> UCHAR * 0x05E1A990 [ -3] "SELECT
>>> Feature.STAsBinary(),convert(varchar(20), PKey) from MetesAndBoundsHeader
>>> WHERE Feature.STIntersects(Geometry::STGeomFromText('POLYGON((-104.18599
>>> 29.2473266843318,-93.22438 29.2473266843318,-93.22438
>>> 41.3707663156682,-104.18599 41.3707663156682,-104.18599
>>> 29.2473266843318))',4326)) = 1 \ 0"
>>> SDWORD -3
>>> (8170)
>>> On Thu, Mar 10, 2011 at 12:04 PM, adams <adams at terrestris.de> wrote:
>>>> Dear Roger,
>>>> if you get an empty image with no error, the first try would be to use a
>>>> simple symbol and no expression in your layer.
>>>> Also ensure, that your extent when querying the map is correct.
>>>> So you make sure, that everything around your datasource is OK.
>>>> Then use a datastring like this one:
>>>> DATA "the_geom from (SELECT Feature from MetesAndBoundsHeader) as foo
>>>> USING UNIQUE PKey USING SRID=4326"
>>>> or however the geometry-column in mssql server is called ;-)
>>>> Regards, Till
>>>> Roger Bedell wrote:
>>>> Good Morning.
>>>> I am currently working with MapServer and the MSSQL Spatial driver. I am
>>>> seeing that MS does not work with a DATA statement like this in the Map
>>>> file:
>>>> DATA "Feature from MetesAndBoundsHeader USING UNIQUE PKey USING
>>>> SRID=4326"
>>>> where PKey is defined like this:
>>>> [PKey] [uniqueidentifier] DEFAULT NEWSEQUENTIALID() ROWGUIDCOL NOT NULL,
>>>> No errors are triggered, however nothing is displayed, including all
>>>> other layers. Is this an issue with the SQL Spatial driver or MapServer? Any
>>>> ideas on how to fix it?
>>>> Thanks!
>>>> Roger Bedell
>>>> _______________________________________________
>>>> mapserver-users mailing listmapserver-users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/mapserver-users
>>>> terrestris GmbH & Co. KG
>>>> Irmintrudisstrasse 17
>>>> 53111 Bonn
>>>> Germany
>>>> Till Adams
>>>> Geschäftsführung
>>>> Tel: +49 (0)228 / 962 899-52
>>>> Fax: +49 (0)228 / 962 899-57adams at terrestris.de http://www.terrestris.de
>>>> Amtsgericht Bonn, HRA 6835
>>>> Komplementärin:
>>>> terrestris Verwaltungs GmbH
>>>> vertreten durch:
>>>> Hinrich Paulsen, Till Adams
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110317/f00b5172/attachment.html
