[mapserver-users] MapServer and Guid USING UNIQUE
Tamas Szekeres
szekerest at gmail.com
Fri Mar 18 07:52:42 EDT 2011
2011/3/18 Roger Bedell <sylvanascent at gmail.com>
> I found this:
> SELECT (select count(*) from QQHeader where PKey<=a.PKey) AS RowNo, a.*
> FROM QQHeader AS a
The problem with this (and with the ROW_NUMBER option as well) is that the
order of the rows may be undeterministic unless an orderby clause is used. I
would rather suggest to use a function (either an UDF or the checksum) to
create and integer is from guid.
BTW: In the development version having an oid should not necessarily be a
requirment in order to have the query option to work. So you may probably
omit the using unique section in the layer definition (not tested by me).
Best regards,
Tamas
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110318/391884a8/attachment-0001.html
