[mapserver-users] Problems getting started with POSTGIS
Jeff Dege
jeff.dege at korterra.com
Fri Mar 18 18:25:26 EDT 2011
I'm not seeing the query - I don't think I'm getting that far.
msPostGISWhichShapes called.
msPostGISParseData called.
msPostGISParseData(): Query error. Error parsing PostGIS DATA variable. Must contain 'geometry from table' or geometry from (subselect) as Foo'. County
But playing around, I saw that I was getting the same error regardless of what I put in the DATA variable. Which made no sense. I tried stuff that should not have worked at all, and saw no difference.
So I looked beyond my problematic DATA variable - and found another DATA variable, later in the LAYER definition.
If you remember, I started this by copying a mapfile that had been working with shapefiles. I'd changed the CONNECTIONTYPE, added a CONNECTION, and a new DATA - but I hadn't deleted the old DATA.
Oops.
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Stephen Woodbridge
Sent: Friday, March 18, 2011 4:44 PM
To: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Problems getting started with POSTGIS
On 3/18/2011 3:41 PM, Andy Colson wrote:
> On 3/18/2011 11:52 AM, Jeff Dege wrote:
>> I've been using MapServer with shapefiles for some time. I'm trying
>> to convert a site to PostGIS, and I'm having problems.
>> I've successfully installed PostGIS on my Ubunto 10.04 box, and
>> copied a number of shapefiles into it, using shp2pgsql. I can view
>> the new tables using qGIS, so I'm sure the data is right.
>> So now I've copies a mapfile that was working against the original
>> shapefiles, and I'm trying to convert it to use PostGIS. I'm working
>> on just one layer, and I'm trying to test that layer with shp2img.
>> I've added to the LAYER definition:
>> LAYER
>> NAME "countyboundaries"
>> CONNECTIONTYPE postgis
>> CONNECTION "host=localhost dbname=test_db user=gis password=xxxxx"
>> DATA "the_geom from gis_schema.county"
>> END
>> As I said, I know the data is in the database, because I can load it
>> as a PostGIS layer from qGIS. Column and table names are right,
>> because when I run "select the_geom from gis_schema.county" in the
>> query tool I get the data.
>> But when I run shp2img from the commandline, I get an error:
>> $ shp2img -m test.map -o test.gif -i GIF -l countyboundaries
>> msDrawMap(): Image handling error. Failed to draw layer named
>> 'countyboundaries'.
>> from table' or 'geometry from (subselect) as foo'. County
>> shp2img is MapServer version 5.6.6, and the output from -v does
>> contain "INPUT=POSTGIS".
>> Any ideas? I'm trying to keep things simple, and it's frustrating
>> when simple doesn't work.
> I cant see anything really wrong. I'm doing mostly the same thing.
> however:
> > CONNECTION "dbname=test_db user=gis password=xxxxx"
> because mapserver and PG run on the same box, I left off the
> host=localhost... not sure if its important.
Yes, it might be, it depends on how postgresql is configured. You can test it with:
psql -U gis test_db
vs:
psql -U gis -h localhost test_db
> > DATA "the_geom from gis_schema.county using unique gid using srid=-1"
> I also have the unique and srid things, again not sure if there'd be a
> difference.
This also might be a problem. In general you should not use srid=-1 in the database of in the mapfile. When you load your data you should specify the correct srid and reference in the mapfile.
in your mapfile add:
MAP
CONFIG MS_ERRORFILE "stderr"
DEBUG 10
then run your shp2img again and you might get more debug info. You can also add the DEBUG 10 to you LAYER and I think it will spit out the SQL it is trying to execute so you can try it in psql and maybe get helpful messages there.
-Steve W
> And as a last hint, you can try bumping up the debug:
> MAP
> CONFIG "MS_ERRORFILE" "/tmp/mapserver.log"
> LAYER
> DEBUG 4
> END
> -Andy
