[mapserver-users] Floating point exception agg png
Daniel Degasperi
daniel.degasperi at r3-gis.com
Mon Mar 21 09:47:07 EDT 2011
I'v encountered following problem with outputformat png (agg driver):
shp2img -m /data/sites/R3-MTB-Public/sito/etc/goldart/mtb.map -l
"ropeway" -e 667072.437052 5153904.693426 677867.431220 5164699.687594
-s 1224 1224 -o test-mtb.png -all_debug 1 (i got a FPE)
The debugger backtrace gives me:
Program received signal SIGFPE, Arithmetic exception.
0x00000000004ba89e in
mapserver::line_image_pattern<mapserver::pattern_filter_bilinear_rgba<mapserver::rgba8>
>::pixel (this=0x7fffffffc940, p=0x7fffffffc43c, x=82, y=-757)
at renderers/agg/include/agg_renderer_outline_image.h:173
173 m_filter->pixel_high_res(m_buf.rows(),
(gdb) bt
#0 0x00000000004ba89e in
#1 0x00000000004ba8fb in
mapserver::renderer_outline_image<mapserver::renderer_base<mapserver::pixfmt_alpha_blend_rgba<mapserver::blender_rgba_pre<mapserver::rgba8,
mapserver::order_bgra>, mapserv_row_ptr_cache<int>, int> >,
> >::pixel (this=0x7fffffffc9e0, p=0x7fffffffc43c, x=82, y=-757)
at renderers/agg/include/agg_renderer_outline_image.h:860
#2 0x00000000004bafba in
mapserver::line_interpolator_image<mapserver::renderer_outline_image<mapserver::renderer_base<mapserver::pixfmt_alpha_blend_rgba<mapserver::blender_rgba_pre<mapserver::rgba8,
> > >::step_hor (this=0x7fffffffc1c0)
at renderers/agg/include/agg_renderer_outline_image.h:668
#3 0x00000000004bb27f in
> >::line3_no_clip (this=0x7fffffffc9e0, lp=..., sx=105681, sy=155778,
ex=101946, ey=147898)
at renderers/agg/include/agg_renderer_outline_image.h:931
#4 0x00000000004c99f9 in
> >::line3 (this=0x7fffffffc9e0, lp=..., sx=105681, sy=155778,
at renderers/agg/include/agg_renderer_outline_image.h:992
#5 0x00000000004cc5b9 in
mapserver::rasterizer_outline_aa<mapserver::renderer_outline_image<mapserver::renderer_base<mapserver::pixfmt_alpha_blend_rgba<mapserver::blender_rgba_pre<mapserver::rgba8,
> >, mapserver::line_coord_sat>::render (this=0x7fffffffc9a0,
close_polygon=false) at
renderers/agg/include/agg_rasterizer_outline_aa.h:540
#6 0x00000000004cc9b5 in
> >, mapserver::line_coord_sat>::add_path<line_adaptor> (
this=0x7fffffffc9a0, vs=..., path_id=0) at
renderers/agg/include/agg_rasterizer_outline_aa.h:177
#7 0x00000000004cca3f in
AGGMapserverRenderer::renderPathPixmapBGRA<line_adaptor> (this=0xf74350,
line=..., pattern=...) at mapagg.cpp:392
#8 0x00000000004cccea in
AGGMapserverRenderer::renderPolylineVectorSymbol<line_adaptor,
mapserver::conv_stroke<mapserver::path_base<mapserver::vertex_block_storage<double,
8u, 256u> >, mapserver::null_markers> > (this=0xf74350, shape=...,
symbol=..., tilewidth=0, tileheight=5, color=..., backgroundcolor=...)
at mapagg.cpp:370
#9 0x00000000004a9b21 in msDrawLineSymbolAGG(._98 *, ._105 *, ._39 *,
._91 *, double) (symbolset=0x822ae0, image=0x937b30, p=0x7fffffffd310,
style=0x87e230, scalefactor=1.3333333333333333)
at mapagg.cpp:1723
#10 0x000000000053d573 in msDrawLineSymbol (symbolset=0x822ae0,
image=0x937b30, p=0x7fffffffd310, style=0x87e230,
scalefactor=1.3333333333333333) at maprendering.c:488
#11 0x0000000000485521 in msDrawShape (map=0x822ab0, layer=0x87c820,
shape=0x7fffffffd310, image=0x937b30, style=0, querymapMode=0) at
mapdraw.c:1962
#12 0x000000000047fe20 in msDrawVectorLayer (map=0x822ab0,
layer=0x87c820, image=0x937b30) at mapdraw.c:1032
#13 0x000000000047f32e in msDrawLayer (map=0x822ab0, layer=0x87c820,
image=0x937b30) at mapdraw.c:822
#14 0x000000000047e1e5 in msDrawMap (map=0x822ab0, querymap=0) at
mapdraw.c:468
#15 0x0000000000440b32 in main (argc=17, argv=0x7fffffffd848) at
shp2img.c:292
When I switch to outputformat jpeg (agg driver) everything is fine.
MapServer is 5.6.6 on 64bit CentOS 5.5
Best regards,
Daniel
Daniel Degasperi R3 GIS Srl - GmbH www.r3-gis.com
