[mapserver-users] Production mapserver
Andy Colson
andy at squeakycode.net
Mon Mar 21 13:28:10 EDT 2011
On 3/21/2011 11:27 AM, Jeff Dege wrote:
> What do we need to do to get Mapserver running in a production
> configuration?
I guess that's up to you. Do you need 100% uptime? Mirrors and backups
and redundancy? You'll also need an ISP that lets you host data. Many
residential plans forbid it. You'll need a commercial plan. Or are you
renting a VSP, or something? Your question is a little vague. Do you
mean internet connections? Hardware? Just mapserver?
> There are packages out there to help new users get mapserver up and
> running in a development/playing-around-in mode, ms4w, etc. But these
> are designed for ease of installation, not performance on a production
> server.
Do you know the level of performance you'll need? How many concurrent
users? Have you put a load on it? Since you said the word
"performance", I'd say go for FastCGI. If you need more performance
than that, well, that's another ballgame.
> I have a set of shapefiles, and some mapfiles I’ve built to display
> them. I have them running on a dev machine, just fine.
> So what do I need to do to go into production.
I have a test box, and a live box... and I try to keep them as exact as
possible. That way when you make changes, and do load tests, and what
not, you know what to expect from the live site. Need to test
something? The more identical your live and test boxes are, the more
sure you can be about your testing.
(Note, however, my live box is running off raid 5, where as my test is
just a single HD. CPU's are close. Software wise, they are the same
though)
> I have a dedicated Ubuntu 10.04 box, that will be doing nothing but
> serving maps through WMS requests, using Mapserver. It currently has
> both Apache and MapServer installed, using the current apt-get packages.
> Should I be using Apache? Or should I use Lighttpd?
Use the one you are most comfortable with. Speed wise it wont matter.
You'll be spending all your time in mapserver code, not apache/lighty
code. (unless, of course, you have huge amounts of static files along
with the maps... but those should all be marked as cacheable, so still,
not gonna make a performance difference)
Cant answer anything about Ubuntu, never used it, run Slackware myself.
I prefer to build mapserver from source. I'm also using mapscript
(with perl), so I build that as well.
> Standard CGI? FastCGI? Some other alternative? (WSGI?)
CGI is slow. FastCGI if you want performance. Never used WSGI.
As background: I run on a dual core amd64 3800, 4 green HD's in
software raid 5, 6 gig of ram, running Slackware64. I think the box
cost me around $400 to build. I get 100K hits a day (about 2 requests a
second), and the box sits 75% idle.
I have about 350 gig of arial imagery, and 25 gig of shapefiles in PostGIS.
It's run on apache/mapscript/mod_perl.
-Andy
